floam
Posts: 5 Joined: Fri Dec 17, 2010 3:45 am
Post
by floam » Fri Dec 17, 2010 3:48 am
On my system video downloads were getting a text/html Content-Type causing Safari to append .html to the end of the filenames. This quick fix got around that.
--- video.phpold 2010-12-16 19:35:57.194047323 -0800
+++ video.php 2010-12-16 19:38:27.650321752 -0800
@@ -89,6 +89,7 @@
$downloadIndex = validInt($_REQUEST['downloadIndex']);
header( "Content-disposition: attachment; filename=".$videoFiles[$downloadIndex]."; size=".filesize($videoFiles[$downloadIndex]) );
+ header( "Content-Type: application/octet-stream" );
readfile( $videoFiles[$downloadIndex] );
exit;
BlankMan
Posts: 147 Joined: Tue Jan 19, 2010 2:53 am
Post
by BlankMan » Fri Dec 17, 2010 10:32 pm
Opera was doing this to me too, might give this a try, thanks.
mastertheknife
Posts: 678 Joined: Wed Dec 16, 2009 4:32 pm
Post
by mastertheknife » Fri Dec 31, 2010 5:37 pm
Complete headers would probably work better.
--- a/web/skins/classic/views/video.php
+++ b/web/skins/classic/views/video.php
@@ -88,7 +88,15 @@ if ( isset($_REQUEST['deleteIndex']) )
if ( isset($_REQUEST['downloadIndex']) )
- header( "Content-disposition: attachment; filename=".$videoFiles[$downloadIndex]."; size=".filesize($videoFiles[$downloadIndex]) );
+ header("Pragma: public");
+ header("Expires: 0");
+ header("Cache-Control: must-revalidate, post-check=0, pre-check=0");
+ header("Cache-Control: private",false); // required by certain browsers
+ header("Content-Description: File Transfer");
+ header("Content-Disposition: attachment; filename=".$videoFiles[$downloadIndex]);
+ header("Content-Transfer-Encoding: binary");
+ header("Content-Type: application/force-download");
+ header("Content-Length: ".filesize($videoFiles[$downloadIndex]));
exit;
EDIT: Fixed missing parenthesis in the code
EDIT 2: Do not use, newer patch in the post below.
mastertheknife.
mastertheknife on Sat Feb 05, 2011 6:46 am, edited 1 time in total.
mastertheknife
Post
by mastertheknife » Sat Feb 05, 2011 6:25 am
I fixed the patch to work for old IE and fixed filenames for Firefox. On my machine the file name was events_1_12487-r1-s1.avi, this is because Firefox doesn't strip paths from the filename but simply replaces them with underscore. I used basename() to strip the path.
Patch was tested on IE6, Opera 10 and Firefox 3.6.
+ header('Content-Disposition: attachment; filename="'.basename($videoFiles[$downloadIndex]).'"'); // basename is required because the video index contains the path and firefox doesn't strip the path but simply replaces the slashes with an underscore.
exit;
Reports from other browsers and versions are welcome.
mastertheknife.
zoneminder
Site Admin
Posts: 5215 Joined: Wed Jul 09, 2003 2:07 pm
Post
by zoneminder » Sun Feb 06, 2011 4:48 pm
This is a strange one. In FireFox for me, everything has been working fine and when clicking on the Download link the default actual suggested by FF is to download the file. However applying this change makes FF suggest opening the link rather than downloading it.
That may be by design and other than requiring one more click it doesn't break anything so I will probably apply the patch anyway.
Phil
floam
Post
by floam » Mon Apr 11, 2011 4:48 am
Probably a better idea to use application/octet-stream than application/force-download. The former is the official type for arbitrary byte data and the latter just works as a side effect. Best would be figuring out what is actually being sent and choose the correct MIME, but that's not as trivial.
