I am getting the following warnings and no makefile is generated,
what other packages are required to be installed ...
i have gcc installed
running on ubuntu 10.10
cssadmin@cw200x4-css0:~/Downloads/ZoneMinder-1.24.2/ZoneMinder-1.24.2$ ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
configure: WARNING: You can call configure with the --with-libarch option.
This tells configure where to find architecture specific libraries.
The default of 'lib' is usually ok but 64 bit machines may require lib64.
e.g. --with-libarch=lib or --with-libarch=lib64
configure: WARNING: You can call configure with the --with-mysql option.
This tells configure where to find the MySql C library and headers if configure cannot
locate them automatically.
e.g. --with-mysql=/usr/local or --with-mysql=/usr
configure: WARNING: You can call configure with the --with-ffmpeg option.
This tells configure where to find the ffmpeg root directory within which are the libavcodec
and libavformat files that can be used to build true MPEG streaming into ZoneMinder. Ensure that
your copy of ffmpeg has installed libraries as well as binaries (use 'make installlib'). If you
are using a local install of ffmpeg you may have to remove or rename a previous real installation
as the headers and libraries from that will probably be picked up before your local copy.
e.g. --with-ffmpeg=/usr/local
configure: WARNING: You can call configure with the --with-extralibs option.
Ordinarily you will need to use this option only when your copy of ffmpeg has been built
with support for additional formats and you would use this option to detail which additional
libraries ffmpeg was built with so that it is able to link successfully with ZoneMinder.
You will need to wrap this option in quotes if it contains any spaces.
e.g. --with-extralibs="-lmp3lame"
configure: error: You must call configure with the --with-webdir option.
This tells configure where to install PHP and web files and scripts.
e.g. --with-webdir=/var/www/html or --with-webdir=/www/vhtdocs/<site>
build issue ... configure
hello,
you have to add options to this command. Try to follow the step by step configuration from victor petersson.
http://viktorpetersson.com/2010/05/23/h ... ts-server/
He used the command:
./configure --with-webdir=/var/www/zm --with-cgidir=/usr/lib/cgi-bin/ --with-webuser=www-data --with-webgroup=www-data ZM_DB_USER=zm ZM_DB_NAME=zm ZM_DB_PASS=yourpassword ZM_SSL_LIB=openssl
hope this helps,
junior
hope this helps,
junior
