Page 1 of 1
Power Requirements for 8 Channel BT878a DVR Card
Posted: Mon Dec 20, 2010 12:20 pm
by Mad Professor
Good day all.
I have just got my new High Performance 8 Channel 240 FPS Zoneminder compatible BT878a DVR card, from http://www.camsecure.co.uk/Zoneminder.html
But once fitted the server now fails to power up.
I have read that this card can be a little power hungy.
Power Supply is a SeaSonic SS-460H2U 460 Watt
+3.3v...20A
+5v.....21A
+12v1...18A
+12v2...18A
-12v....0.8A
+5vsb...2A
Motherboard is a Tyan S2882-D
Can you please advice.
Posted: Mon Dec 20, 2010 7:21 pm
by camsecure
HI
The problem of no boot when the card is fitted is usually due to the PCI slot type.
That type of card needs a 5 volt PCI slot although the notches in the board suggest it will work in a 3 volt slot. Many new motherboards have only 3 volt slots or a combination of 3 and 5 volt type. The card must be fitted in a 5 volt PCI slot or the machine wont be able to boot.
More details of this will be on the Camsecure website in the section for these cars by 9 AM tomorrow.
Best regards
LES...
Posted: Tue Dec 21, 2010 12:35 am
by curtishall
This card is a generic / cheap card that is incorrectly keyed. You need a card that is keyed and setup for 3.3V or 5V.
