Pico 2000 Delay in video Fedora 14
andyasselin
Post by andyasselin »
Hi I got pico 2000 card they delay in video it seem lag out
Camera setting are on video for linux 2
I can'nt seem to get them work on video one for linux maybe issues ?
Also instrested in suggestion for alt card choice
set for camera are
ntsc
grey scale
no frame spefic
352x 288
I try diffent share memory configure
Two pico card
2 camera on 1 card
Systems Specs are
Fedora 14 ( Was tottaly pain to get video from compare to ubunto )
Cpu Intel(R) Pentium(R) 4 CPU 2.80GHz
onboard video 1 tb hard disk sata
DELL DV051 model number
d0003000
[ 7.269040] bttv0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
[ 7.269112] bttv0: gpio: en=00000000, out=00000000 in=00f36fff [init]
[ 7.269325] bttv0: tuner absent
[ 7.269331] bttv0: the autoload option is obsolete.
[ 7.269336] bttv0: use option msp3400, tda7432 or tvaudio to
[ 7.269342] bttv0: override which audio module should be used.
[ 7.269551] bttv0: registered device video0
[ 7.269740] bttv0: registered device vbi0
[ 7.269767] bttv0: PLL: 28636363 => 35468950 .
[ 16.945038] bttv: Bt8xx card found (1).
[ 16.945058] bttv 0000:03:02.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 16.945076] bttv1: Bt878 (rev 2) at 0000:03:02.0, irq: 18, latency: 64, mmio: 0xd0001000
motox
Re: Pico 2000 Delay in video Fedora 14
Post by motox »
Any resolutions?
I have same issue except mine only works with V4L2 PAL setting on grey scale.
Old settings worked with NTSC V4L1 320 x 240 rgb24.
bb99
Post by bb99 »
Try using BGR24 for your palette.
