Problem with ffmpeg version
Posted: Fri Dec 24, 2010 5:58 pm
I'm trying to compile ZM on Gentoo x32. Linux version 2.6.36.2
Standart instruction (from googling) doesn't work
I've try ffmpeg with version from distro :
ffmpeg-0.5_p20373
ffmpeg-0.6
ffmpeg-0.6_p25423
ffmpeg-0.6_p25767
and trunk from SVN on 24-12-2010
: ZM don't compile (from distro command and from /dev/hands)
error on emerge ZM on ffmpeg-0.6_p25767 is:
and during the ./configure command ZM says, that FFMPEG libraries are:
libavutil/avutil.h: check for missing prerequisite headers?
libavutil/avutil.h: see the Autoconf documentation
libavutil/avutil.h: section "Present But Cannot Be Compiled"
libavutil/avutil.h: proceeding with the compiler's result
## Report this to support@zoneminder.com ##
libavcodec/avcodec.h
libavformat/avformat.h
libswscale/swscale.h
after that ZM says:
zm_mpeg.h <multiple> and stops
in case of manual compiling the zm from trunk:
./configure --with-libarch=lib64 --with-mysql=/usr --with-ffmpeg=/mnt/devel/zm/ffmpeg-0.6_p25767 --with-extralibs="-lmp3lame" --with-webdir=/var/www/localhost/htdocs/zm --with-cgidir=/var/www/localhost/htdocs/zm/cgi-bin
zm_ffmpeg.h:33:2: error: #error "No location for avutils.h found"
zm_ffmpeg.h:40:2: error: #error "No location for avcodec.h found"
zm_ffmpeg.h:47:2: error: #error "No location for avformat.h found"
zm_ffmpeg.h:55:2: error: #error "No location for swscale.h found"
zm_mpeg.h errors
I'm trying to manual compile the ffmpeg (confit whith and whitout x264 support)
ffmpeg-0.4.7.tar.gz
ffmpeg-0.4.8.tar.gz
ffmpeg-0.4.9-pre1.tar.gz
ffmpeg-17177 : libswscale/swscale.h error
ffmpeg-19768 : libswscale/swscale.c error
ffmpeg doesn't compile
Can (anyone) please tell me the working version of ffmpeg and ZM version
or can your help me fand my mistake...
Thanks. Denis
zm configure options are:
./configure --with-libarch=lib64 --with-mysql=/usr --with-ffmpeg=/usr --with-extralibs="-lmp3lame" --with-webdir=/var/www/localhost/htdocs/zm --with-cgidir=/var/www/localhost/htdocs/zm/cgi
ffmpeg-0.5_p20373
ffmpeg-0.6
ffmpeg-0.6_p25423
ffmpeg-0.6_p25767
after that ZM says:
zm_mpeg.h errors
ffmpeg-0.4.7.tar.gz
ffmpeg-0.4.8.tar.gz
Thanks. Denis
