I can visit the camera via
http://192.168.1.253:2000/CgiStart/Imag ... on=320x240
but when I visit the camear via zoneminder,
which i set the remote host name as : username:passwrd@192.168.1.253
remote host path as:/CgiStart/ImageViewer?Resolution=320x240
the source turns red and the screen of the zoneminder turns black, is there anybody knows how to solve it?
[solved]BL-C1 Camera not work in zoneminder
Try: /nphContinuousServerPush?Resolution=640x480&Quality=Standard
http://www.zoneminder.com/forums/viewto ... light=blc1
HI, I have read the post and following the instruction on that post but still get no hopebb99 wrote:Try: /nphContinuousServerPush?Resolution=640x480&Quality=Standard
now my host name is: username:passwrd@192.168.1.253
and the host port is: 2000
and the host path is : /nphContinuousServerPush?Resolution=640x480&Quality=Standard
the status of source turns "orange" and the video is "black" now
Oh so close, orange is progress. Now change "capture width" to 320 and "capture height" to 240; change the remote host path to "/nphContinuousServerPush?Resolution=320x240&Quality=Standard" and set the camera to the same resolution, double check the port 2000 on the camera and see what happens. Make sure the monitor function is set to monitor and the camera is enabled. You will not get green results until you change from monitor to something else, like Modect.
it works now, thank you very muchbb99 wrote:Oh so close, orange is progress. Now change "capture width" to 320 and "capture height" to 240; change the remote host path to "/nphContinuousServerPush?Resolution=320x240&Quality=Standard" and set the camera to the same resolution, double check the port 2000 on the camera and see what happens. Make sure the monitor function is set to monitor and the camera is enabled. You will not get green results until you change from monitor to something else, like Modect.
