Alarm State of Specific Monitor
seyi
Post by seyi »
I am doing some development in ZoneMinder and I have come across a problem. I need to determine if a monitor is in the alarmed state or not. This works by getting the status for single frame monitors, but when dealing with mpeg it does not. I tried to use the stream call, but I do not see a way to specify the monitor id (and it times out after 2 calls due to the connKey). Is this the right approach? Any help would be appreciated.
jdhar
Re: Alarm State of Specific Monitor
Post by jdhar »
seyi wrote:Hello,
What's the context you are trying to determine this in? ie: web/php, command-line etc... one thing you could consider is the web interface can determine if it the monitor is in Alarm, so take a look at the source for the Monitor View and see how it determines that.
eyeZm, Native iPhone App for ZoneMinder: http://www.eyezm.com
Version 1.3 now available on iTunes, introduces Montage view, HTTPS/SSL support and H264 native streaming!
Subscribe to RSS feed for updates: http://www.eyezm.com/rssfeed.xml
