Configure 4 chip, 16 channel/port, Conexant Fusion 878A
infinity005
Post by infinity005 »
I'm trying to configure this card (see images) on linux. So far, very little luck. I believe I'm falling short on the correct bttv module options. It has a ribbon cable that converts 4 card slots to 4 ports each for a total of 16.
It's from a security system I have identified as purchased from eyemaxdvr.com.
Loading bttv identifies it as unknown/generic and lspci shows up as "Brooktree Corporation Bt878 Video Capture"
Any help is much appreciated!
PacoLM
Post by PacoLM »
Searching the forum is very helpful: http://www.zoneminder.com/forums/viewto ... light=878a
infinity005
I'm confused. I don't see how that card matches. Please elaborate.
