I just did a brand new install of Fedora 13 and followed the directions at:
http://www.zoneminder.com/wiki/index.ph ... _12_and_13
I get "forbidden" trying to get to the basic console.
Please...short term, I need to know what to fix for this problem but more importantly, is there a set of installation instructions that work? From top to bottom? I don't care which distro, I'm absolutely desperate, I've tried before and failed to get a working ZM system.
Is there an official installation guide that tells you what permissions need to be set, and where?
Or is total mastery of Apache and MySQL simply assumed for anybody wanting to deal with ZM?
Sigh...
Brand new install, "forbidden" at localhost/zm
OK...turns out it didn't save somehow at step 14:
http://localhost/zm/
What the heck?
So now I don't get a permissions failure...I get a blank screen (literally, *nothing*?) at:(14) Edit as root /etc/httpd/conf.d/zoneminder.conf to remove the 'Deny from All' line. It even says 'DELETE THIS LINE', so it should be easy to find. Save it.
What the heck?
Solved via comment 1 at:
https://bugzilla.redhat.com/show_bug.cgi?id=556166
At /etc/php.ini, change short_open_tag to On.
Again: there is NO such thing as a complete install guide to ZM. Anywhere. Sigh.
I frackin hate Zoneminder. I detest it with all my being. I wish it would go away one day and get replaced by something sane. Gag.
From the very step by step you were using. You must have gotten in a hurry...[18] Last thing - edit the SECOND entry of short_open_tag down at line 229. Again as root (menu-Application::System Tools::Terminal), gedit /etc/php.ini
Change short_open_tag from 'off' to 'on'
[19] reboot. open browser, type 'localhost/zm'
