Storage deviate zoneminder
kronostime
Post by kronostime »
I have a 1 tb hard drive and want the content there I will store it as it would have to do? that route would have to put in zoneminder? as I get that hard drive is mounted before starting zoneminder? graciasss
Flash_
Post by Flash_ »
midian
Post by midian »
To answer directly, yes, you can definitely use a dedicated hard drive. You can:
A: use symbolic links for the events, images, & sounds folders
B: change the paths in the web "Options/Paths" tab
Of course, follow the documentation for full details.
Flash_
Post by Flash_ »
No - do not use symbolic links. At least with ubuntu and debian packages, as they will be removed during upgrade losing your entire database.
