Single cam working, help configuring second on PV-143
Posted: Tue Jan 18, 2011 5:59 pm
I have a single BW camera that I've had working for a while now. I recently purchased a CBN DFL-20S and want to run both of these off the PV-143 until I can get a 4 chip PV-149.
I can get either camera to work in ZM independently, but not together. When I add the second input /dev/videoX device channel 2 the text is yellow not green and I get the same video stream from my other camera on this one when clicking in ZM.
I've tried changing both cameras to the same settings except "Device Channel" and I get the same results. Any help?
this is in my zmdc.log when I add the second camera:
I used the install script which adjust the shared memory.
zmu -d /dev/video1 -q -v
01/18/11 12:55:24.450010 zmdc[14614].INF ['zmc -d /dev/video1' stopping at 11/01/18 12:55:24]
01/18/11 12:55:24.473691 zmdc[14614].INF ['zmc -d /dev/video1' exited normally]
01/18/11 12:55:24.634301 zmdc[14614].INF ['zmc -d /dev/video1' starting at 11/01/18 12:55:24, pid = 15118]
01/18/11 12:55:24.973459 zmdc[14614].WAR [Can't find process with command of 'zma -m 6']
Video Device: /dev/video1
General Capabilities
Driver: bttv
Card: BT878 video (ProVideo PV143)
Bus: PCI:0000:04:06.0
Version: 0.9.18
Type: 0x5000015
Supports video capture (X)
Does not support video output
Supports frame buffer overlay
Supports VBI capture
Does not support VBI output
Does not have tuner
Does not have radio
Supports read/write i/o (X)
Does not support async i/o
Supports streaming i/o (X)
Standards:
NTSC
NTSC-M
NTSC-M-JP
NTSC-M-KR
PAL
PAL-BG
PAL-H
PAL-I
PAL-DK
PAL-M
PAL-N
PAL-Nc
PAL-60
SECAM
SECAM-B
SECAM-G
SECAM-H
SECAM-DK
SECAM-L
SECAM-Lc
Formats:
8 bpp, gray (GREY)
8 bpp, dithered color (HI24)
15 bpp RGB, le (RGBO)
15 bpp RGB, be (RGBQ)
16 bpp RGB, le (RGBP)
16 bpp RGB, be (RGBR)
24 bpp RGB, le (BGR3)
32 bpp RGB, le (BGR4)
32 bpp RGB, be (RGB4)
4:2:2, packed, YUYV (YUYV)
4:2:2, packed, UYVY (UYVY)
4:2:2, planar, Y-Cb-Cr (422P)
4:2:0, planar, Y-Cb-Cr (YU12)
4:2:0, planar, Y-Cr-Cb (YV12)
4:1:1, planar, Y-Cb-Cr (411P)
4:1:0, planar, Y-Cb-Cr (YUV9)
4:1:0, planar, Y-Cr-Cb (YVU9)
Crop Capabilities
Bounds: 838 x 504
Default: 768 x 480
Current: 768 x 480
Inputs: 4
Input 0
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
Input 1
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 2
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 3
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
