spec as follows…
The camera's are..dhcppc20:/etc/modprobe.d# zmu -d /dev/video0 -q -v
Video Device: /dev/video0
General Capabilities
Driver: bttv
Card: BT878 video ( *** UNKNOWN/GENER
Bus: PCI:0000:05:08.0
Version: 0.9.17
Type: 0x5010015
Supports video capture (X)
Does not support video output
Supports frame buffer overlay
Supports VBI capture
Does not support VBI output
Has tuner
Does not have radio
Supports read/write i/o (X)
Does not support async i/o
Supports streaming i/o (X)
Standards:
NTSC
NTSC-M
NTSC-M-JP
NTSC-M-KR
PAL
PAL-BG
PAL-H
PAL-I
PAL-DK
PAL-M
PAL-N
PAL-Nc
PAL-60
SECAM
SECAM-B
SECAM-G
SECAM-H
SECAM-DK
SECAM-L
SECAM-Lc
Formats:
8 bpp, gray (GREY)
8 bpp, dithered color (HI24)
15 bpp RGB, le (RGBO)
15 bpp RGB, be (RGBQ)
16 bpp RGB, le (RGBP)
16 bpp RGB, be (RGBR)
24 bpp RGB, le (BGR3)
32 bpp RGB, le (BGR4)
32 bpp RGB, be (RGB4)
4:2:2, packed, YUYV (YUYV)
4:2:2, packed, UYVY (UYVY)
4:2:2, planar, Y-Cb-Cr (422P)
4:2:0, planar, Y-Cb-Cr (YU12)
4:2:0, planar, Y-Cr-Cb (YV12)
4:1:1, planar, Y-Cb-Cr (411P)
4:1:0, planar, Y-Cb-Cr (YUV9)
4:1:0, planar, Y-Cr-Cb (YVU9)
Crop Capabilities
Bounds: 838 x 600
Default: 747 x 576
Current: 747 x 576
Inputs: 4
Input 0
Type: Tuner
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
Input 1
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 2
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 3
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
I have found the camera's only work on 500 * 375 Pixels and on grey only with PALnc setting…CCD Sensor 1/4" SONY Super-HAD
Resolution 420 TVL
Lens 3.6mm Fixed
Effective Pixels NTSC: 510(H) x 492(V) / PAL: 500(H) x 582(V)
LED Quantity 18pcs
IR Range Up to 15m
Minimum Illumination 0 Lux / F2.0. IR ON: 0 Lux
Gamma 0.45 (AGC off)
Scanning System 2:1 Interlace
Sync System Interior
Back Light Compensation ON
White Balance Auto
Gain Control Auto
Flicker Correction ON
Video Output 1 Vp-p 75 Ohm, F-Plug Connector
Input Voltage DC12V +/- 10%
Input Current 90mA (IR off) / 270mA (IR on)
Operating Temperature -10ºC to 55ºC
Operating Humidity 80% RH
I want colour
So I must be missing something...
