My bttv card (connexant 878a):
http://www.zoneminder.com/wiki/index.php/Pico2000
..is recognized by linux like: bttv0 and /dev/video0.
fswebcam -d /dev/video0 --list-inputs shows:
1 composite0
2 composite1
3 composite2
4 composite3
modprobe:
options i2c-algo-bit bit_test=1
options bttv card=77 tuner=4 radio=0 triton1=0 vsfx=0 autoload=0
Why just one /dev/video0 , not 4?I have 2 cameras connected to it.
Just one program in the same time can use /dev/video0, so just 1 cam can be connected to my DVR?
Is any solution in zone minder for this?
pico2000(connexant 878a), problem
The Pico2000 like all of the clone single BT878 chip cards can only capture one frame at a time, because there is only one A/D inside the chip that is multiplexed to 4 input channels so it will support 4 cameras at the same time but will only capture a single image from each one in turn.
edgar5's explanation is correct you address the single card with the /dev/video0 then you address the port on the card with the channel 0, 1, 2, 3 that your cameras are attached too.
note the card can only do 25fps with a single camera attached if you attach more then the fps will drop to under 5 per camera, I have a pico2000 clone with all 4 ports filled and get approximately 2fps on each camera.
