I am looking for help to auto start a system based on three KWorld DVB-T 220 capture cards.
The system works, but before I start zoneminder I have to 'initialise' each card manually using mplayer. So if there is a power failure the system cannot be restarted without operator input at the terminal. If zoneminder is started without the initialisation step then the cameras just show black screens.
The system is based on fedora 13 (although this problem has existed in all versions I have tried 9-13). The CCTV cameras are attached to a distributed analogue tv system so that they can be viewed on any TV in the building. The zoneminder system then takes a feed from the TV system. What I think is happening is that when the system restarts each card losses the channel information and what the mplayer command does is reset the card to the correct channel.
Has anyone any experience of setting these cards to a channel using a startup script?
Thanks in advance
KWorld DVB-T 220 - autostart
Jump to
- General
- ↳ Announcements
- ↳ Website Issues
- Support
- ↳ ZoneMinder 1.36.x
- ↳ ZoneMinder 1.34.x
- ↳ Mobile Apps and Event Server
- ↳ Docker
- ↳ ZoneMinder Distributions
- ↳ ZoneMinder Translations
- ↳ Archive [End of Life Versions]
- ↳ ZoneMinder 1.35.x Development Branch
- ↳ ZoneMinder 1.33.x Development Branch
- ↳ ZoneMinder 1.32.x
- ↳ ZoneMinder 1.31.x
- ↳ ZoneMinder 1.30.x
- ↳ ZoneMinder 1.29.x
- ↳ ZoneMinder 1.28.x
- ↳ ZoneMinder 1.27.x
- ↳ ZoneMinder 1.26.x
- ↳ ZoneMinder 1.25.x
- ↳ ZoneMinder 1.24.x
- ↳ ZoneMinder Previous Versions
- Development
- ↳ ZoneMinder 1.37.x Development Branch
- ↳ Feature Requests
- ↳ User Contributions
- Miscellaneous
- ↳ ZoneMinder Hints & Tips
- ↳ Non-ZoneMinder Chat
- ↳ Jobs / For Sale / Wanted / Exchange
- ↳ Hardware Compatibility List
- ↳ Hardware Queries
