After setting up the TZ environment variable in /etc/init.d/zoneminder and exporting it that corrected the time in the timestamp for the camera images. (C and C++ code that use time functions).
Then I changed the php.ini in both the apache2 and cli in /usr/php5/ and that fixed the console time displayed (Php web pages time)
Now all the event times are off by 1 hour still so it looks like there are issues with perl5.10 Manip so I was wondering if anyone else ran into these and has successfully fixed them (perl scripts)?
It might be a good topic in the FAQs since it is not covered.
Thanks in advance
Cheers
Giancarlo
