about cambozola and win2k
fernando
Post by fernando »
ok i have two win2k machines.. my own and a server..
cuz a change mi HD i decide to install all over again.
so i upgrade to ie6 but a discover that cambozola dont work dont stream..
in mi other machine "server" works fine.. so i dont find anything about this bug..
so i install some SP. and works. i thing was w2k sp4 ... so if you have same problem start installing Sevice packs. windows and explorer.
Fernando Diaz.
zoneminder
Site Admin
Re: about cambozola and win2k
Post by zoneminder »
Interesting.
I suspect this may have something to do with the Java VM that is installed, as I can't really think what else could cause Cambozola not to work. The whole issue of JVMs is a bit of a minefield at the moment, especially with the various versions of Windows and which JVM they get, if get one at all!
Cheers,
Phil,
fernando
Post by fernando »
i installa JVM and more stuff .. but someting a see is a page that have a streamiing video and use cambozola and works wen cambozola on zm dont. the only diference i discover is, they transmit over 8080 port ..
