I am running Zoneminder livecd version 1.22.2 which is running fine with an Axis 210 camera
I have purchased two more cameras Cisco WVC2300 and Cisco PVC2300
I hav e followed the Docs on the hardware compatibility list(this is why i bouight these models in particular)
I have setup the host and path to match the documenation for both still JPEG and MJPEG no luck, when hitting refresh in zone minder, it will sometimes show up green(rarely), sometimes yellow(hardly), sometimes red(mostly)
i have checked the log file with debug level 9 logging turned on and can see this is the last entry:
02/14/11 17:20:37.654974 zmc_m4[22221].INF-zmc.cpp/183 [Starting Capture]
02/14/11 17:20:37.673841 zmc_m4[22221].DB3-zm_remote_camera.cpp/159 [Connected to host, socket = 6]
02/14/11 17:20:37.673984 zmc_m4[22221].DB3-zm_remote_camera.cpp/180 [Request sent]
02/14/11 17:20:39.677186 zmc_m4[22221].ERR-zm_remote_camera.cpp/195 [Select timed out]
I have tried to access this using the web interface of the camera itself, and it works fine, tried it using the url that is being passed to zoneminder.
Any help would be appreciated.
-David
Apart from this hiccup, Zoneminder is running well on my test box(P4 2.0 512MB ram, 40GB HDD)
