Upgrade Issues.
FantaXP7
Upgrade Issues.
Post by FantaXP7 »
Hello guys,
I have been having some problems when trying to upgrade to newer versions of zoneminder.
Here are some notes:
This may result in a large file if you have a lot of events.
Press 'y' for a backup or 'n' to continue : y
Creating backup to zm-1.23.3.dump. This may take several minutes.
Database successfully backed up to zm-1.23.3.dump, proceeding to upgrade.
Upgrading database to version 1.24.1
Loading config from DB
No option 'ZM_OPT_MPEG' found, removing at /usr/share/perl5/ZoneMinder/ConfigAdmin.pm line 1702, <STDIN> line 2.
No option 'ZM_PATH_MPEG_ENCODE' found, removing at /usr/share/perl5/ZoneMinder/ConfigAdmin.pm line 1702, <STDIN> line 2.
No option 'ZM_WEB_MONTAGE_MAX_COLS' found, removing at /usr/share/perl5/ZoneMinder/ConfigAdmin.pm line 1702, <STDIN> line 2.
No option 'ZM_WEB_MONTAGE_WIDTH' found, removing at /usr/share/perl5/ZoneMinder/ConfigAdmin.pm line 1702, <STDIN> line 2.
No option 'ZM_WEB_MONTAGE_HEIGHT' found, removing at /usr/share/perl5/ZoneMinder/ConfigAdmin.pm line 1702, <STDIN> line 2.
No option 'ZM_WEB_DOUBLE_BUFFER' found, removing at /usr/share/perl5/ZoneMinder/ConfigAdmin.pm line 1702, <STDIN> line 2.
No option 'ZM_WEB_FRAMES_PER_LINE' found, removing at /usr/share/perl5/ZoneMinder/ConfigAdmin.pm line 1702, <STDIN> line 2.
No option 'ZM_WEB_FRAME_LINES' found, removing at /usr/share/perl5/ZoneMinder/ConfigAdmin.pm line 1702, <STDIN> line 2.
No option 'ZM_WEB_DVR_STREAMING' found, removing at /usr/share/perl5/ZoneMinder/ConfigAdmin.pm line 1702, <STDIN> line 2.
Saving config to DB
Database successfully upgraded from version 1.23.3.
Database successfully upgraded from version 1.24.0.
then in zm tried to access camera:
Notice: Undefined index: passwordHash in /usr/share/zoneminder/includes/functions.php on line 156
Notice: Undefined index: remoteAddr in /usr/share/zoneminder/includes/functions.php on line 156
Warning: Cannot modify header information - headers already sent by (output started at /usr/share/zoneminder/includes/functions.php:156) in /usr/share/zoneminder/includes/functions.php on line 97
Warning: Cannot modify header information - headers already sent by (output started at /usr/share/zoneminder/includes/functions.php:156) in /usr/share/zoneminder/includes/functions.php on line 98
Warning: Cannot modify header information - headers already sent by (output started at /usr/share/zoneminder/includes/functions.php:156) in /usr/share/zoneminder/includes/functions.php on line 99
Warning: Cannot modify header information - headers already sent by (output started at /usr/share/zoneminder/includes/functions.php:156) in /usr/share/zoneminder/includes/functions.php on line 100
Warning: Cannot modify header information - headers already sent by (output started at /usr/share/zoneminder/includes/functions.php:156) in /usr/share/zoneminder/includes/functions.php on line 101
Any idea what might be going on here?
