what do you guys use as your antivirus?
getting tired of avast - keeps crashing... any recommendations? (XP x64)
thanks!
thanks!
Try www.Avira.com, for me the best free antivirus.
- punch-card
Look at ClamWin or Microsoft Security Essentials .
I run ClamWin (http://www.clamav.net/lang/en/ ) on a netbook and when I build a system for people short on funds, I use MSE. Both are free, and no ad's.
Best Regards
Mike
Mike
I use ZenOK Free Security software and heres a really good free anti viris program called
superantispyware but don't think the free verison runs in the background so I use both
as for my firewall it's built in the router
Re: what do you guys use as your antivirus?
For winders
users superantispyware and avg free together works well.
norton and most others are worthless. Believe me I fix microsoft garbage for a living.
Don't have to fix my own since I run linux
I have a much simpler solution for you. Make 2 accounts one limited one admin. Now google hide windows xp account; hide the admin. When there logged into the limited account and want to be a admin all they do is right click the application that needs admin -> then run as --> admin : pass
Prevents almost all explotes.
Another thing i do is disabble p2p traffic i haven had a virus issues in years. As well as disable any "anti-virus".
well, i have tried, it's okay, good site.Try , for me the best free antivirus.
Now and I always used Avast free Antivirus ......
Its working is best and it has no extra load on my computer
Have a Good Day
Have a Good Day
Don't compare yourself to others . You have no idea what their journey is all about!
ClamAV would be my recommendation. It is maintained by SourceFire which created and owns Snort. Many others use the snort libraries for their security software and repackage it (like McAfee). It's opensource, it's cross platform, it's free, up-to-date, and consumes low resources.
The most popular antivirus programm for MC-users are MSE、avast and comodo internet security. I use avast.
Setze dir ein hohes Ziel...Setze dir ein festes, kein unbestimmtes Ziel. Setze dir ein unerschütterliches, kein wackliges Ziel!
avast seldom if ever crashes on a stable system, I suspect you have another issue causing it.
That being said, do yourself a favor and get off of Windows... Linux, OSX, FreeBSD, ChromeOS,doesn't matter.... friends dont let friends use windows, its an admin headache.
