Deep Storage
tibetfreedom
Deep Storage
Post by tibetfreedom »
I have enabled this,
switched zoneminder off and then on again.
Now is it enabled ?
I don't know ….
tibetfreedom
Re: Deep Storage
tibetfreedom wrote:I have enabled this,
Now is it enabled ?
I don't know ….
It appears to be but disk Storage still shows 29%
How do I get rid of the old files ?
Also How do I limit the data saved ?
I want to purge data so the disk does not fill…
Thanks...
PacoLM
Post by PacoLM »
Go to filters, then enable the "PurgeWhenFull" filter to the disk percentage you want, then save it and check the run in background.
PacoLM
