Newbie Install Fail
Posted: Fri Feb 25, 2011 3:00 am
by nixxer
Hello everyone, I've never really used forums until now, so I will do my best to form a valid and accurate question.
I have an Intel P4 2.4GHz with 1GB RAM and 160GB HDD, on it I have installed CentOS 5.5. I have two sony cctv cameras with standard BNC connections, and a QSEE QSPDVR04 4 channel card with the Techwell 6800 chipset.
I downloaded the tw68-v2 driver sources from gitorious, and they required a newer kernel to compile so I updated to the 2.6.37-1 kernel from ELRepo. The driver compiled and installed with no problem. I proceeded to follow the Centos5 instructions on the wiki and installed ZM v1.24.2.
I then used `zmu -d /dev/video0 -v -q` to determine the capture card's settings and configured my monitors accordingly.
As it currently stands, when I try to view one of the monitors, I get a black screen with the monitor name and timestamp at the top left corner. If I use channels 0 and 3 (1 and 4 on the card), I get nothing, and no errors. If I use channels 1 and 2 however (the two middle inputs on the card), I get 4-6 of the following error per second in /var/log/messages:
Feb 24 21:24:44 cam1 kernel: tw6800[0]/0: [e3729980/3] timeout - dma=0x34fc9000
There are no other errors that I can see anywhere, and it seems to run properly. It keeps recording blank events, not sure why.
I've exhausted my options on freenode #zoneminder, as the people there were not able to offer any advice that worked, and it seems I can only get help for about 30 minutes per day, then everyone disappears.
Please advise what I should do to get this working.
xawtv output
Posted: Fri Feb 25, 2011 3:14 am
by nixxer
[root@cam1 ~]# xawtv -hwscan
This is xawtv-3.95, running on Linux/i686 (2.6.37-1.el5.elrepo)
looking for available devices
/dev/video0: OK [ -device /dev/video0 ]
type: v4l2
flags: capture
[root@cam1 ~]# xawtv -device /dev/video0
WARNING: Your X-Server has no DGA support.
/dev/video0 [v4l2]: no overlay support
v4l-conf had some trouble, trying to continue anyway
Warning: Cannot convert string "-*-ledfixed-medium-r-*--39-*-*-*-c-*-*-*" to type FontStruct
ioctl: VIDIO_G_CTRL(id=9963781;value=1056997505): Invalid argument[/img]
v4l-info output
Posted: Fri Feb 25, 2011 3:18 am
by nixxer
[root@cam1 ~]# v4l-info
### v4l2 device info [/dev/video0] ###
general info
VIDIOC_QUERYCAP
driver : "tw68"
card : "GENERIC"
bus_info : "PCI:0000:00:09.0"
version : 0.0.4
capabilities : 0x5000011 [VIDEO_CAPTURE,VBI_CAPTURE,READWRITE,STREAMING]
standards
VIDIOC_ENUMSTD(0)
index : 0
id : 0xb000 [NTSC_M,NTSC_M_JP,?]
frameperiod.numerator : 1001
frameperiod.denominator : 30000
framelines : 525
VIDIOC_ENUMSTD(1)
index : 1
framelines : 525
VIDIOC_ENUMSTD(2)
index : 2
id : 0x2000 [NTSC_M_JP]
framelines : 525
VIDIOC_ENUMSTD(3)
index : 3
framelines : 525
VIDIOC_ENUMSTD(4)
index : 4
framelines : 525
VIDIOC_ENUMSTD(5)
index : 5
id : 0xff [PAL_B,PAL_B1,PAL_G,PAL_H,PAL_I,PAL_D,PAL_D1,PAL_K]
frameperiod.denominator : 25
framelines : 625
VIDIOC_ENUMSTD(6)
index : 6
id : 0x7 [PAL_B,PAL_B1,PAL_G]
framelines : 625
VIDIOC_ENUMSTD(7)
index : 7
framelines : 625
VIDIOC_ENUMSTD(8)
index : 8
framelines : 625
VIDIOC_ENUMSTD(9)
index : 9
id : 0xe0 [PAL_D,PAL_D1,PAL_K]
framelines : 625
VIDIOC_ENUMSTD(10)
index : 10
framelines : 525
VIDIOC_ENUMSTD(11)
index : 11
framelines : 625
VIDIOC_ENUMSTD(12)
index : 12
framelines : 625
VIDIOC_ENUMSTD(13)
index : 13
framelines : 525
VIDIOC_ENUMSTD(14)
index : 14
id : 0xff0000 [SECAM_B,SECAM_D,SECAM_G,SECAM_H,SECAM_K,SECAM_K1,SECAM_L,?ATSC_8_VSB]
framelines : 625
VIDIOC_ENUMSTD(15)
index : 15
id : 0x10000 [SECAM_B]
framelines : 625
VIDIOC_ENUMSTD(16)
index : 16
id : 0x40000 [SECAM_G]
framelines : 625
VIDIOC_ENUMSTD(17)
index : 17
id : 0x80000 [SECAM_H]
framelines : 625
VIDIOC_ENUMSTD(18)
index : 18
id : 0x320000 [SECAM_D,SECAM_K,SECAM_K1]
framelines : 625
VIDIOC_ENUMSTD(19)
index : 19
id : 0x400000 [SECAM_L]
framelines : 625
VIDIOC_ENUMSTD(20)
index : 20
id : 0x800000 [?ATSC_8_VSB]
framelines : 625
inputs
VIDIOC_ENUMINPUT(0)
index : 0
type : CAMERA
audioset : 1
tuner : 0
std : 0xffffff [PAL_B,PAL_B1,PAL_G,PAL_H,PAL_I,PAL_D,PAL_D1,PAL_K,PAL_M,PAL_N,PAL_Nc,PAL_60,NTSC_M,NTSC_M_JP,?,?,SECAM_B,SECAM_D,SECAM_G,SECAM_H,SECAM_K,SECAM_K1,SECAM_L,?ATSC_8_VSB]
status : 0x0 []
VIDIOC_ENUMINPUT(1)
index : 1
type : CAMERA
audioset : 1
tuner : 0
status : 0x0 []
VIDIOC_ENUMINPUT(2)
index : 2
type : CAMERA
audioset : 1
tuner : 0
status : 0x10000 [NO_SYNC]
VIDIOC_ENUMINPUT(3)
index : 3
type : CAMERA
audioset : 1
tuner : 0
status : 0x0 []
video capture
VIDIOC_ENUM_FMT(0,VIDEO_CAPTURE)
index : 0
type : VIDEO_CAPTURE
flags : 0
description : "15 bpp RGB, le"
pixelformat : 0x4f424752 [RGBO]
VIDIOC_ENUM_FMT(1,VIDEO_CAPTURE)
index : 1
flags : 0
description : "15 bpp RGB, be"
pixelformat : 0x51424752 [RGBQ]
VIDIOC_ENUM_FMT(2,VIDEO_CAPTURE)
index : 2
flags : 0
description : "16 bpp RGB, le"
pixelformat : 0x50424752 [RGBP]
VIDIOC_ENUM_FMT(3,VIDEO_CAPTURE)
index : 3
flags : 0
description : "16 bpp RGB, be"
pixelformat : 0x52424752 [RGBR]
VIDIOC_ENUM_FMT(4,VIDEO_CAPTURE)
index : 4
flags : 0
description : "24 bpp RGB, le"
pixelformat : 0x33524742 [BGR3]
VIDIOC_ENUM_FMT(5,VIDEO_CAPTURE)
index : 5
flags : 0
description : "24 bpp RGB, be"
pixelformat : 0x33424752 [RGB3]
VIDIOC_ENUM_FMT(6,VIDEO_CAPTURE)
index : 6
flags : 0
description : "32 bpp RGB, le"
pixelformat : 0x34524742 [BGR4]
VIDIOC_ENUM_FMT(7,VIDEO_CAPTURE)
index : 7
flags : 0
description : "32 bpp RGB, be"
pixelformat : 0x34424752 [RGB4]
VIDIOC_ENUM_FMT(8,VIDEO_CAPTURE)
index : 8
flags : 0
description : "4:2:2 packed, YUYV"
pixelformat : 0x56595559 [YUYV]
VIDIOC_ENUM_FMT(9,VIDEO_CAPTURE)
index : 9
flags : 0
description : "4:2:2 packed, UYVY"
pixelformat : 0x59565955 [UYVY]
VIDIOC_G_FMT(VIDEO_CAPTURE)
fmt.pix.width : 720
fmt.pix.height : 576
fmt.pix.pixelformat : 0x33524742 [BGR3]
fmt.pix.field : INTERLACED
fmt.pix.bytesperline : 2160
fmt.pix.sizeimage : 1244160
fmt.pix.colorspace : SMPTE170M
fmt.pix.priv : 0
vbi capture
VIDIOC_G_FMT(VBI_CAPTURE): Invalid argument
controls
VIDIOC_QUERYCTRL(BASE+0)
type : INTEGER
minimum : -128
maximum : 127
step : 1
default_value : 20
flags : 0
VIDIOC_QUERYCTRL(BASE+1)
type : INTEGER
minimum : 0
maximum : 255
step : 1
default_value : 100
flags : 0
VIDIOC_QUERYCTRL(BASE+2)
type : INTEGER
minimum : 0
maximum : 255
step : 1
default_value : 128
flags : 0
VIDIOC_QUERYCTRL(BASE+3)
type : INTEGER
minimum : -128
maximum : 127
step : 1
default_value : 0
flags : 0
### video4linux device info [/dev/video0] ###
general info
VIDIOCGCAP
type : 0x5 [CAPTURE,TELETEXT]
channels : 4
audios : 0
maxwidth : 720
maxheight : 576
minwidth : 48
minheight : 32
channels
VIDIOCGCHAN(0)
channel : 0
tuners : 0
flags : 0x0 []
type : CAMERA
norm : 0
VIDIOCGCHAN(1)
channel : 1
tuners : 0
flags : 0x0 []
type : CAMERA
norm : 0
VIDIOCGCHAN(2)
channel : 2
tuners : 0
flags : 0x0 []
type : CAMERA
norm : 0
VIDIOCGCHAN(3)
channel : 3
tuners : 0
flags : 0x0 []
type : CAMERA
norm : 0
tuner
ioctl VIDIOCGTUNER: Invalid argument
audio
VIDIOCGAUDIO
audio : 0
volume : 0
bass : 0
treble : 0
VIDIOCGPICT
brightness : 58596
hue : 32896
colour : 32896
contrast : 25700
whiteness : 0
depth : 24
palette : RGB24
buffer
ioctl VIDIOCGFBUF: Invalid argument
window
VIDIOCGWIN
x : 0
y : 0
width : 720
height : 576
chromakey : 0
flags : 0
zmu output
by nixxer
[root@cam1 ~]# zmu -d /dev/video0 -v -q
Video Device: /dev/video0
General Capabilities
Driver: tw68
Card: GENERIC
Bus: PCI:0000:00:09.0
Version: 0.0.4
Type: 0x5000011
Supports video capture (X)
Does not support video output
Does not support frame buffer overlay
Supports VBI capture
Does not support VBI output
Does not have tuner
Does not have radio
Supports read/write i/o (X)
Does not support async i/o
Supports streaming i/o (X)
Standards:
NTSC
NTSC-M
NTSC-M-JP
NTSC-M-KR
NTSC-443
PAL
PAL-BG
PAL-H
PAL-I
PAL-DK
PAL-M
PAL-N
PAL-Nc
PAL-60
SECAM
SECAM-B
SECAM-G
SECAM-H
SECAM-DK
SECAM-L
SECAM-Lc
Formats:
15 bpp RGB, le (RGBO)
15 bpp RGB, be (RGBQ)
16 bpp RGB, le (RGBP)
16 bpp RGB, be (RGBR)
24 bpp RGB, le (BGR3)
24 bpp RGB, be (RGB3)
32 bpp RGB, le (BGR4)
32 bpp RGB, be (RGB4)
4:2:2 packed, YUYV (YUYV)
4:2:2 packed, UYVY (UYVY)
Crop Capabilities
Bounds: 720 x 288
Default: 720 x 288
Current: 720 x 288
Inputs: 4
Input 0
Type: Camera
Audioset: 00000001
Standards: 0xffffff
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
Input 1
Type: Camera
Audioset: 00000001
Standards: 0xffffff
Power on (X)
Signal detected (X)
Input 2
Type: Camera
Audioset: 00000001
Standards: 0xffffff
Power on (X)
Signal detected (X)
Input 3
Type: Camera
Audioset: 00000001
Standards: 0xffffff
Power on (X)
Signal detected (X)
v4l-conf output
Posted: Fri Feb 25, 2011 3:20 am
by nixxer
[root@cam1 ~]# v4l-conf
ioctl VT_GETSTATE: Invalid argument
gstreamer-properties output
Posted: Fri Feb 25, 2011 3:22 am
by nixxer
[root@cam1 ~]# gstreamer-properties
(process:11392): GStreamer-WARNING **: The GStreamer function gst_init_get_option_group() was
called, but the GLib threading system has not been initialised
yet, something that must happen before any other GLib function
is called. The application needs to be fixed so that it calls
if (!g_thread_supported ()) g_thread_init(NULL);
as very first thing in its main() function. Please file a bug
against this application.
cannot open display:
IT WORKS!!
Posted: Fri Feb 25, 2011 7:10 am
by nixxer
Hey, somehow or another, I restarted zm a few times playing with options, and now it works! I had to set my cameras to PAL for some reason though, and I have a big green bar across the screen. The capture card's specs say it records 30FPS on NTSC though, and uses MPEG4 compression. Is that something I need to enable?
