Hello
Iam running two Vivotek IP7330 cams with 320x240 @5fps and always have a load of 0.8 to 1.06 using Modect.
I tried to reduce the the load by installing libjpeg-mmx-dev to use the MMX feature.
Do I have to activate it somehow (Iam not a Linux expert...). What else can I do to reduce the load by optimized things. Is there a detailed HowTo or similar. I could only find very common explanations...
