Page 1 of 1
Buffer overflow - in virtual recv function.
Posted: Mon Feb 28, 2011 4:10 am
by ruehlchr
Hi all,
I'd like to point out a bug:
1) a dynamic 'buffer' initialized with maxLen
2) the ::recv() method reads bytes into buffer and return nBytes that can be equal to maxLen
3) buffer[nByte] = \0 !!!!!! if the received bytes == maxLen we overflow and write a null
outside the barrier.. that can be cause seg-faults
Faulty Code
       virtual int recv( std::string &msg, size_t maxLen ) const
        char buffer[maxLen];
        int nBytes = 0;
                if ( (nBytes = ::recv( mSd, buffer, sizeof(buffer), 0 )) < 0 )
            Debug( 1, "Recv of %d bytes max to string on sd %d failed: %s", maxLen, mSd, strerror(errno) );
            return( nBytes );
        buffer[nBytes] = '\0';
        msg = buffer;
        return( nBytes );
My suggestion
        char buffer[maxLen + 1];
        int32_t nBytes = 0;
                if ( (nBytes = ::recv( mSd, buffer, (uint32_t) maxLen , 0 )) < 0 )
            Debug( 1, "Recv of %d bytes max to string on sd %d failed: %s", (uint32_t) maxLen, mSd, strerror(errno) );
            return( nBytes );
        msg = buffer;
        return( nBytes );
same same for the method using the msg.capacity()
File: zm_comms.h line 339 onwards
Please comment.
Chris
Posted: Mon Feb 28, 2011 3:54 pm
by bdmcnxn
Yeah, the buffer print in case of buffer full, the Debug() macro (I think that's what it is) message print could easily case a segfault, if it's last char isn't '\0').
What's the patch submission policy here ??
PS> am pretty new to ZM, and have no code contribution so far.
