Zoneminder not working
makaveli0129
Post by makaveli0129 »
I am in desperate need of someone's help i have been trying to get this working for some time now. To give a synapsis of what has happened i had problem with one of my cards on linux so i bought a kodicom 8800 card works fine with all inputs on xawtv. I cannot get zoneminder to let me add any new monitor. When i click on source to set up the monitor nothing happens....I've seriously waited over an hour for something to change and nothing.....i've searched through the logs i have no errors anywhere. I really need to get this running and am desperate any help.... here is my message.log
Mar  1 00:15:18 jr-EP45T-UD3P zmfix[1525]: INF [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.01525]
Mar  1 00:15:20 jr-EP45T-UD3P zmpkg[1559]: INF [Command: start]
Mar  1 00:15:21 jr-EP45T-UD3P zmfix[1598]: INF [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.01598]
Mar  1 00:15:21 jr-EP45T-UD3P zmdc[1600]: INF [Server starting at 11/03/01 00:15:21]
Mar  1 00:15:24 jr-EP45T-UD3P zmdc[1600]: INF ['zmfilter.pl' starting at 11/03/01 00:15:24, pid = 1705]
Mar  1 00:15:24 jr-EP45T-UD3P zmdc[1705]: INF ['zmfilter.pl' started at 11/03/01 00:15:24]
Mar  1 00:15:24 jr-EP45T-UD3P zmdc[1600]: INF ['zmaudit.pl -c' starting at 11/03/01 00:15:24, pid = 1707]
Mar  1 00:15:24 jr-EP45T-UD3P zmdc[1707]: INF ['zmaudit.pl -c' started at 11/03/01 00:15:24]
Mar  1 00:15:24 jr-EP45T-UD3P zmdc[1600]: INF ['zmwatch.pl' starting at 11/03/01 00:15:24, pid = 1709]
Mar  1 00:15:24 jr-EP45T-UD3P zmdc[1709]: INF ['zmwatch.pl' started at 11/03/01 00:15:24]
Mar  1 00:15:25 jr-EP45T-UD3P zmwatch[1709]: INF [Watchdog starting]
Mar  1 00:15:25 jr-EP45T-UD3P zmwatch[1709]: INF [Watchdog pausing for 30 seconds]
Mar  1 00:15:26 jr-EP45T-UD3P zmfilter[1705]: INF [Scanning for events]
Mar  1 00:15:26 jr-EP45T-UD3P kernel: [   47.412410] hda-intel: IRQ timing workaround is activated for card #1. Suggest a bigger bdl_pos_adj.
Mar  1 00:16:09 jr-EP45T-UD3P kernel: [   90.720513] bttv0: audio absent, no audio device found!
Mar  1 00:17:07 jr-EP45T-UD3P kernel: [  148.620573] bttv0: registered device video0
Mar  1 00:17:07 jr-EP45T-UD3P kernel: [  148.620596] bttv0: registered device vbi0
Mar  1 00:17:07 jr-EP45T-UD3P kernel: [  148.620622] bttv0: PLL: 28636363 => 35468950 .
Mar  1 00:17:07 jr-EP45T-UD3P kernel: [  148.633456] bttv0: PLL: 28636363 => 35468950 .
Mar  1 00:17:07 jr-EP45T-UD3P kernel: [  148.633462] bttv0: PLL: 28636363 => 35468950 .. ok
Mar  1 00:17:07 jr-EP45T-UD3P kernel: [  148.648545]  ok
Mar  1 00:17:07 jr-EP45T-UD3P kernel: [  148.652514]  ok
Mar  1 00:17:46 jr-EP45T-UD3P kernel: [  187.244520] bttv: Bt8xx card found (1).
Mar  1 00:17:46 jr-EP45T-UD3P kernel: [  187.244535] bttv 0000:07:09.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
Mar  1 00:17:46 jr-EP45T-UD3P kernel: [  187.244545] bttv1: Bt878 (rev 17) at 0000:07:09.0, irq: 18, latency: 32, mmio: 0xe8402000
Mar  1 00:17:46 jr-EP45T-UD3P kernel: [  187.244567] bttv1: using: IVC-200 [card=102,insmod option]
Mar  1 00:17:46 jr-EP45T-UD3P kernel: [  187.244637] bttv1: tuner absent
Mar  1 00:17:46 jr-EP45T-UD3P kernel: [  187.244638] bttv1: the autoload option is obsolete.
Mar  1 00:17:46 jr-EP45T-UD3P kernel: [  187.244639] bttv1: use option msp3400, tda7432 or tvaudio to
Mar  1 00:17:46 jr-EP45T-UD3P kernel: [  187.244640] bttv1: override which audio module should be used.
Mar  1 00:17:46 jr-EP45T-UD3P kernel: [  187.244683] bttv1: registered device video1
Mar  1 00:17:46 jr-EP45T-UD3P kernel: [  187.244726] bttv1: registered device vbi1
Mar  1 00:17:46 jr-EP45T-UD3P kernel: [  187.244751] bttv1: PLL: 28636363 => 35468950 .. ok
Mar  1 00:17:56 jr-EP45T-UD3P kernel: [  197.279595] audit_printk_skb: 6 callbacks suppressed
Mar  1 00:17:56 jr-EP45T-UD3P kernel: [  197.279597] type=1400 audit(1298956676.343:23): apparmor="STATUS" operation="profile_replace" name="/usr/lib/cups/backend/cups-pdf" pid=1940 comm="apparmor_parser"
Mar  1 00:17:56 jr-EP45T-UD3P kernel: [  197.280276] type=1400 audit(1298956676.343:24): apparmor="STATUS" operation="profile_replace" name="/usr/sbin/cupsd" pid=1940 comm="apparmor_parser"
Mar  1 00:18:24 jr-EP45T-UD3P kernel: [  225.868523] bttv: Bt8xx card found (2).
Mar  1 00:18:24 jr-EP45T-UD3P kernel: [  225.868538] bttv 0000:07:0a.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
Mar  1 00:18:24 jr-EP45T-UD3P kernel: [  225.868549] bttv2: Bt878 (rev 17) at 0000:07:0a.0, irq: 16, latency: 32, mmio: 0xe8404000
Mar  1 00:18:24 jr-EP45T-UD3P kernel: [  225.868571] bttv2: using: IVC-200 [card=102,insmod option]
Mar  1 00:18:24 jr-EP45T-UD3P kernel: [  225.868644] bttv2: tuner absent
Mar  1 00:18:24 jr-EP45T-UD3P kernel: [  225.868646] bttv2: the autoload option is obsolete.
Mar  1 00:18:24 jr-EP45T-UD3P kernel: [  225.868647] bttv2: use option msp3400, tda7432 or tvaudio to
Mar  1 00:18:24 jr-EP45T-UD3P kernel: [  225.868648] bttv2: override which audio module should be used.
Mar  1 00:18:24 jr-EP45T-UD3P kernel: [  225.868698] bttv2: registered device video2
Mar  1 00:18:24 jr-EP45T-UD3P kernel: [  225.868718] bttv2: registered device vbi2
Mar  1 00:18:24 jr-EP45T-UD3P kernel: [  225.868743] bttv2: PLL: 28636363 => 35468950 .
Mar  1 00:18:24 jr-EP45T-UD3P kernel: [  225.869374] bttv2: PLL: 28636363 => 35468950 .
Mar  1 00:18:24 jr-EP45T-UD3P kernel: [  225.870170] bttv2: PLL: 28636363 => 35468950 .. ok
Mar  1 00:18:24 jr-EP45T-UD3P kernel: [  225.884627]  ok
Mar  1 00:18:24 jr-EP45T-UD3P kernel: [  225.900513]  ok
Mar  1 00:19:03 jr-EP45T-UD3P kernel: [  264.476524] bttv: Bt8xx card found (3).
Mar  1 00:19:03 jr-EP45T-UD3P kernel: [  264.476540] bttv 0000:07:0b.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
Mar  1 00:19:03 jr-EP45T-UD3P kernel: [  264.476551] bttv3: Bt878 (rev 17) at 0000:07:0b.0, irq: 20, latency: 32, mmio: 0xe8406000
Mar  1 00:19:03 jr-EP45T-UD3P kernel: [  264.476574] bttv3: using: IVC-200 [card=102,insmod option]
Mar  1 00:19:03 jr-EP45T-UD3P kernel: [  264.476648] bttv3: tuner absent
Mar  1 00:19:03 jr-EP45T-UD3P kernel: [  264.476649] bttv3: the autoload option is obsolete.
Mar  1 00:19:03 jr-EP45T-UD3P kernel: [  264.476650] bttv3: use option msp3400, tda7432 or tvaudio to
Mar  1 00:19:03 jr-EP45T-UD3P kernel: [  264.476652] bttv3: override which audio module should be used.
Mar  1 00:19:03 jr-EP45T-UD3P kernel: [  264.476702] bttv3: registered device video3
Mar  1 00:19:03 jr-EP45T-UD3P kernel: [  264.476730] bttv3: registered device vbi3
Mar  1 00:19:03 jr-EP45T-UD3P kernel: [  264.476754] bttv3: PLL: 28636363 => 35468950 .
Mar  1 00:19:03 jr-EP45T-UD3P kernel: [  264.477638] bttv3: PLL: 28636363 => 35468950 .
Mar  1 00:19:03 jr-EP45T-UD3P kernel: [  264.477642] bttv3: PLL: 28636363 => 35468950 .. ok
Mar  1 00:19:03 jr-EP45T-UD3P kernel: [  264.492546]  ok
Mar  1 00:19:03 jr-EP45T-UD3P kernel: [  264.508510]  ok
Mar  1 00:19:39 jr-EP45T-UD3P kernel: [  300.714489] padlock: VIA PadLock not detected.
Mar  1 00:19:42 jr-EP45T-UD3P kernel: [  303.100532] bttv: Bt8xx card found (4).
Mar  1 00:19:42 jr-EP45T-UD3P kernel: [  303.100557] bttv 0000:07:0c.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
Mar  1 00:19:42 jr-EP45T-UD3P kernel: [  303.100571] bttv4: Bt878 (rev 17) at 0000:07:0c.0, irq: 19, latency: 32, mmio: 0xe8408000
Mar  1 00:19:42 jr-EP45T-UD3P kernel: [  303.102817] bttv4: using: IVC-200 [card=102,insmod option]
Mar  1 00:19:42 jr-EP45T-UD3P kernel: [  303.103050] bttv4: tuner absent
Mar  1 00:19:42 jr-EP45T-UD3P kernel: [  303.103051] bttv4: the autoload option is obsolete.
Mar  1 00:19:42 jr-EP45T-UD3P kernel: [  303.103052] bttv4: use option msp3400, tda7432 or tvaudio to
Mar  1 00:19:42 jr-EP45T-UD3P kernel: [  303.103054] bttv4: override which audio module should be used.
Mar  1 00:19:42 jr-EP45T-UD3P kernel: [  303.103367] bttv4: registered device video4
Mar  1 00:19:42 jr-EP45T-UD3P kernel: [  303.103578] bttv4: registered device vbi4
Mar  1 00:19:42 jr-EP45T-UD3P kernel: [  303.103606] bttv4: PLL: 28636363 => 35468950 .
Mar  1 00:19:42 jr-EP45T-UD3P kernel: [  303.107301] bttv4: PLL: 28636363 => 35468950 .
Mar  1 00:19:42 jr-EP45T-UD3P kernel: [  303.108733] bttv4: PLL: 28636363 => 35468950 .. ok
Mar  1 00:19:42 jr-EP45T-UD3P kernel: [  303.128168]  ok
Mar  1 00:19:42 jr-EP45T-UD3P kernel: [  303.132513]  ok
Mar  1 00:20:12 jr-EP45T-UD3P kernel: [  333.607152] sr 0:0:1:0: [sr0] CDB: Volume set (in), Read cd: be 00 ff ff ff ff 00 00 01 10 00 00
Mar  1 00:20:12 jr-EP45T-UD3P kernel: [  333.607174] ata1.00: hard resetting link
Mar  1 00:20:13 jr-EP45T-UD3P kernel: [  333.928026] ata1.01: hard resetting link
Mar  1 00:20:13 jr-EP45T-UD3P kernel: [  334.404115] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Mar  1 00:20:13 jr-EP45T-UD3P kernel: [  334.404140] ata1.01: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Mar  1 00:20:13 jr-EP45T-UD3P kernel: [  334.440695] ata1.00: configured for UDMA/133
Mar  1 00:20:13 jr-EP45T-UD3P kernel: [  334.460277] ata1.01: configured for UDMA/100
Mar  1 00:20:13 jr-EP45T-UD3P kernel: [  334.460965] ata1: EH complete
Mar  1 00:20:20 jr-EP45T-UD3P kernel: [  341.724527] bttv: Bt8xx card found (5).
Mar  1 00:20:20 jr-EP45T-UD3P kernel: [  341.724544] bttv 0000:07:0d.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
Mar  1 00:20:20 jr-EP45T-UD3P kernel: [  341.724555] bttv5: Bt878 (rev 17) at 0000:07:0d.0, irq: 18, latency: 32, mmio: 0xe840a000
Mar  1 00:20:20 jr-EP45T-UD3P kernel: [  341.724574] bttv5: using: IVC-200 [card=102,insmod option]
Mar  1 00:20:20 jr-EP45T-UD3P kernel: [  341.724743] bttv5: tuner absent
Mar  1 00:20:20 jr-EP45T-UD3P kernel: [  341.724744] bttv5: the autoload option is obsolete.
Mar  1 00:20:20 jr-EP45T-UD3P kernel: [  341.724745] bttv5: use option msp3400, tda7432 or tvaudio to
Mar  1 00:20:20 jr-EP45T-UD3P kernel: [  341.724746] bttv5: override which audio module should be used.
Mar  1 00:20:20 jr-EP45T-UD3P kernel: [  341.725061] bttv5: registered device video5
Mar  1 00:20:20 jr-EP45T-UD3P kernel: [  341.725274] bttv5: registered device vbi5
Mar  1 00:20:20 jr-EP45T-UD3P kernel: [  341.725298] bttv5: PLL: 28636363 => 35468950 .
Mar  1 00:20:20 jr-EP45T-UD3P kernel: [  341.725645] bttv5: PLL: 28636363 => 35468950 .
Mar  1 00:20:20 jr-EP45T-UD3P kernel: [  341.729207] bttv5: PLL: 28636363 => 35468950 .. ok
Mar  1 00:20:20 jr-EP45T-UD3P kernel: [  341.744529]  ok
Mar  1 00:20:20 jr-EP45T-UD3P kernel: [  341.756518]  ok
Mar  1 00:20:59 jr-EP45T-UD3P kernel: [  380.352535] bttv: Bt8xx card found (6).
Mar  1 00:20:59 jr-EP45T-UD3P kernel: [  380.352551] bttv 0000:07:0e.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
Mar  1 00:20:59 jr-EP45T-UD3P kernel: [  380.352563] bttv6: Bt878 (rev 17) at 0000:07:0e.0, irq: 16, latency: 32, mmio: 0xe840c000
Mar  1 00:20:59 jr-EP45T-UD3P kernel: [  380.352581] bttv6: using: IVC-200 [card=102,insmod option]
Mar  1 00:20:59 jr-EP45T-UD3P kernel: [  380.352658] bttv6: tuner absent
Mar  1 00:20:59 jr-EP45T-UD3P kernel: [  380.352660] bttv6: the autoload option is obsolete.
Mar  1 00:20:59 jr-EP45T-UD3P kernel: [  380.352661] bttv6: use option msp3400, tda7432 or tvaudio to
Mar  1 00:20:59 jr-EP45T-UD3P kernel: [  380.352662] bttv6: override which audio module should be used.
Mar  1 00:20:59 jr-EP45T-UD3P kernel: [  380.352719] bttv6: registered device video6
Mar  1 00:20:59 jr-EP45T-UD3P kernel: [  380.352742] bttv6: registered device vbi6
Mar  1 00:20:59 jr-EP45T-UD3P kernel: [  380.352767] bttv6: PLL: 28636363 => 35468950 .
Mar  1 00:20:59 jr-EP45T-UD3P kernel: [  380.353561] bttv6: PLL: 28636363 => 35468950 .
Mar  1 00:20:59 jr-EP45T-UD3P kernel: [  380.353650] bttv6: PLL: 28636363 => 35468950 .. ok
Mar  1 00:20:59 jr-EP45T-UD3P kernel: [  380.368598]  ok
Mar  1 00:20:59 jr-EP45T-UD3P kernel: [  380.384510]  ok
Mar  1 00:21:38 jr-EP45T-UD3P kernel: [  418.976525] bttv: Bt8xx card found (7).
Mar  1 00:21:38 jr-EP45T-UD3P kernel: [  418.976541] bttv 0000:07:0f.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
Mar  1 00:21:38 jr-EP45T-UD3P kernel: [  418.976553] bttv7: Bt878 (rev 17) at 0000:07:0f.0, irq: 20, latency: 32, mmio: 0xe840e000
Mar  1 00:21:38 jr-EP45T-UD3P kernel: [  418.976571] bttv7: using: IVC-200 [card=102,insmod option]
Mar  1 00:21:38 jr-EP45T-UD3P kernel: [  418.976644] bttv7: tuner absent
Mar  1 00:21:38 jr-EP45T-UD3P kernel: [  418.976646] bttv7: the autoload option is obsolete.
Mar  1 00:21:38 jr-EP45T-UD3P kernel: [  418.976647] bttv7: use option msp3400, tda7432 or tvaudio to
Mar  1 00:21:38 jr-EP45T-UD3P kernel: [  418.976648] bttv7: override which audio module should be used.
Mar  1 00:21:38 jr-EP45T-UD3P kernel: [  418.976698] bttv7: registered device video7
Mar  1 00:21:38 jr-EP45T-UD3P kernel: [  418.976720] bttv7: registered device vbi7
Mar  1 00:21:38 jr-EP45T-UD3P kernel: [  418.976744] bttv7: PLL: 28636363 => 35468950 .
Mar  1 00:21:38 jr-EP45T-UD3P kernel: [  418.977609] bttv7: PLL: 28636363 => 35468950 .
Mar  1 00:21:38 jr-EP45T-UD3P kernel: [  418.977615] bttv7: PLL: 28636363 => 35468950 .. ok
Mar  1 00:21:38 jr-EP45T-UD3P kernel: [  418.992552]  ok
Mar  1 00:21:38 jr-EP45T-UD3P kernel: [  419.008511]  ok
