Page 1 of 1
Internet Explorer can't login ?
Posted: Sat Mar 20, 2004 4:31 pm
by wimg
Does anyone know why I can't login to ZoneMinder with Internet Explorer ? I tried on several systems, but I just get the login screen again. Netscape 7.x is no problem, but IE doens't work.
Re: Internet Explorer can't login ?
Posted: Sat Mar 20, 2004 5:08 pm
by zoneminder
Hi Wim,
Do you have cookies enabled? That is the only thing you really need to authentication to work. Alternatively you can run in non-authenticated mode.
Phil,
Posted: Sat Mar 20, 2004 5:17 pm
by wimg
That problem seems to be solved now... I reinstalled completely and it works.
However, now I have this problem :
- If I enable mpeg-generation for live stream, my Netscape asks for an external application.
- Internet Explorer still won't display a live stream, it will only show 1 image.
Posted: Sat Mar 20, 2004 5:20 pm
by zoneminder
IE won't play a motion jpeg stream, but it should be able to manage an 'asf' video stream, if you have the Windows Media Player plugin. Is that what you mean?
Phil,
Posted: Sat Mar 20, 2004 5:27 pm
by wimg
Yes that's what I mean. It won't start the asf video stream. It just displays me 1 picture, that's it.
