when i click on the monitor i get all the events that have been triggered but i don't see anything for the monitor. Zoneminder is recording fine but the live stream isn't showing anything please see below links for pictures of what everything looks like:
http://www.box.net/shared/b4ray8hers
as you can see it doesn't display the live stream and i can't find out why...
Zoneminder no pic
what cameras are you using? local or remote?
post apache's log, I have a hunch you're getting the same error I am since I can record events but no playback of any kind
i've seen this on the forums a couple of times, tho none of the fixes mentioned have worked for me
good luck!
[Thu Mar 10 10:48:39 2011] [error] [client 192.168.192.2] socket_sendto( /tmp/zms-007399s.sock ) failed: Connection refused, referer: http://10.1.1.12/zm/index.php?view=watch&mid=4
[Thu Mar 10 10:48:39 2011] [error] [client 192.168.192.2] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-007399s.sock ) failed: Connection refused',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://10.1.1.12/zm/index.php?view=watch&mid=4
good luck!
