(solved) 1.24.2 / ubuntu 10.04 / no video / DST ?
redxiii
Post by redxiii »
i am suddenly unable to view video from my cameras. i am thinking it might be related to DST. i am in Arizona. system time is correct but time shown in ZM-Console window is 1 hr later.
when i click on a camera name to view the feed, i see no feed. firefox tells me i need additional plugins to view the page, but no plugins can be found. if i browse to the camera's IP address i can view the feed fine. when i try to replay events, also no video is shown. i can view the individual frames fine, though. Montage view shows nothing as well.
redxiii
Re: 1.24.2 / ubuntu 10.04 / no video / DST ?
Post by redxiii »
hello??
not sure if it is related, but this shows up in my /var/log/apache2/error.log when i try to click on a camera to view its stream. 192.168.1.20 is my computer and 192.168.1.50 is the ZM machine:
[Mon Mar 21 16:23:01 2011] [error] [client 192.168.1.20] PHP Deprecated:  Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 828, referer: https://192.168.1.50/zm/index.php
[Mon Mar 21 16:23:05 2011] [error] [client 192.168.1.20] socket_sendto( /tmp/zms-721958s.sock ) failed: No such file or directory, referer: https://192.168.1.50/zm/index.php?view=watch&mid=1
[Mon Mar 21 16:23:05 2011] [error] [client 192.168.1.20] array (\n  0 => \n  array (\n    'file' => '/usr/share/zoneminder/ajax/stream.php',\n    'line' => 55,\n    'function' => 'ajaxError',\n    'args' => \n    array (\n      0 => 'socket_sendto( /tmp/zms-721958s.sock ) failed: No such file or directory',\n    ),\n  ),\n  1 => \n  array (\n    'file' => '/usr/share/zoneminder/index.php',\n    'line' => 116,\n    'args' => \n    array (\n      0 => '/usr/share/zoneminder/ajax/stream.php',\n    ),\n    'function' => 'require_once',\n  ),\n), referer: https://192.168.1.50/zm/index.php?view=watch&mid=1
redxiii
Post by redxiii »
yes, DST was the problem. found the solution, no thanks to the search function of this forum (disallowing search for 'time').
i found this thread, http://www.zoneminder.com/forums/viewto ... f=6&t=8447 and figured out how to configure the PHP timezone. once i did that and restarted apache, video is showing up again!
