I bought two cheap "Heden Visioncam" IP cams from pixmania. It is basically the same camera as Foscam FI8918W and I found instructions how to enable the Pan-Tilt controls of these cameras. Everything but the IR leds on/off works just fine, and the left-right pan controls seems to be mirrored but this is my first working Zoneminder installation so those are my least conserns right now.
I edited out most of my message because I just did not understand the way ZM works.
OK, it records now all the time 640 x 480 @ 15 fps so it takes quite a lot of space, now I gotta figure out how to set it 1 fps on idle and 15fps on alarm instances when something moves on the marked zones.
Still, the Subject retains the same, the "Choose Preset" setting wont stay on...
