SOLVED: zmwatch ERR Can't get shared memory id '7a6d0001'
Flyte
Post by Flyte »
Hi all,
I tried searching for this but apparently the words 'get', 'shared', and 'memory' are too common and were removed from my search?!
Zoneminder will show me no video feeds in the control panel, and the following error is shown in the /tmp/zmwatch.log file:
zmwatch[6414].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
I also get the following error in my /var/log/apache2/error.log:
[error] [client x.x.x.x] array (\n  0 => \n  array (\n    'file' => '/usr/share/zoneminder/ajax/stream.php',\n    'line' => 55,\n    'function' => 'ajaxError',\n    'args' => \n    array (\n      0 => 'socket_sendto( /tmp/zms-397924s.sock ) failed: No such file or directory',\n    ),\n  ),\n  1 => \n  array (\n    'file' => '/usr/share/zoneminder/index.php',\n    'line' => 116,\n    'args' => \n    array (\n      0 => '/usr/share/zoneminder/ajax/stream.php',\n    ),\n    'function' => 'require_once',\n  ),\n), referer: [h][t][t][p][:]//x.x.x.x/zoneminder/index.php?view=watch&mid=1
(IPs removed and links broken to be less "spamy" for a new user..)
I'm using the debian package from the unstable repository.
Any ideas what this could be or where else I can look for more information?
Many thanks
Edit: Marked as solved.. thanks! :)
PacoLM
Re: zmwatch ERR Can't get shared memory id '7a6d0001'
Post by PacoLM »
Look here, the parts that talks about shared memory http://www.zoneminder.com/forums/viewto ... 21&t=17346
