SOLVED: zmwatch ERR Can't get shared memory id '7a6d0001'
Posted: Fri Mar 18, 2011 2:33 pm
Hi all,
I tried searching for this but apparently the words 'get', 'shared', and 'memory' are too common and were removed from my search?!
Zoneminder will show me no video feeds in the control panel, and the following error is shown in the /tmp/zmwatch.log file:
I also get the following error in my /var/log/apache2/error.log:
(IPs removed and links broken to be less "spamy" for a new user..)
I'm using the debian package from the unstable repository.
Any ideas what this could be or where else I can look for more information?
Many thanks
Edit: Marked as solved.. thanks!
zmwatch[6414].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
[error] [client x.x.x.x] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-397924s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: [h][t][t][p][:]//x.x.x.x/zoneminder/index.php?view=watch&mid=1
Many thanks
