I really could write down the procedures I made (actually very little) if you gave me the rights to put URL's in my posts.
I did not rename the Foscams .pm file, that is something that you could help me with.
I should rename it correctly "HedenVisioncam.pm" but when I did that, the PanTilt controls were vice-versa again... Sometimes just restarting zoneminder wont make the changes, they only apply when I reboot Ubuntu. Maybe its a Ubuntu thing, I previously used Gentoo for several years. Now testing with Ubuntu just for the fun and change.
libjpeg-turbo is working smoothly also, i just created the symlink to turbojpeg and cpu loads dropped about 30% on AMD 5000+ system and two 640x480 @ 8 fps IP cams motion detecting.
Still learning the modetc parameters, very intresting stuff indeed. Now I just cannot wait to get my hands on some real Axis PTZ cameras!!
BTW with Axis PTZ cameras, can I view the Streams from Axis lets say 720p @ 20fps at the same time when Zoneminder idle-records 5fps ? Prob a stupid question, cause I can do it even with this cheap "toy" cams of mine.
