Zoneminder 1.24.2, Ubuntu 10.10
snakeater
Post by snakeater »
I`m haveing big problems with getting zoneminder to work. I have Creative live can Vista! [Bus 005 Device 002: ID 041e:4052 Creative Technology, Ltd Live! Cam Vista IM]. I turn off gspca driver and get to work ov519-jpeg. I installed zoneminder by first installing apache then php, then mySQL and last zoneminder. I done this: chmod 777 /dev/video0 (also 660, 666). I put video0 in source. But I can not see the picture and coulor of /dev/video0 (0) is red. Can anyone put a light on this? The camera is working under cheese but I can not get picture under zoneminder. OS - Ubuntu 10.10, zm - 1.24.2
mastertheknife
Re: Zoneminder 1.24.2, Ubuntu 10.10
Post by mastertheknife »
Hi, please attach errors from your system log (tail -n100 /var/log/messages)
mastertheknife
Kfir Itzhak.
snakeater
Post by snakeater »
Hello here what I got from tail -n100 /var/log/messages
lab709@lab709:~$ tail -n100 /var/log/messages
Mar 22 10:58:22 lab709 kernel: [ 8.936168] parport_pc 00:08: reported by Plug and Play ACPI
Mar 22 10:58:22 lab709 kernel: [ 8.936221] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
Mar 22 10:58:22 lab709 kernel: [ 8.970371] Linux video capture interface: v2.00
Mar 22 10:58:22 lab709 kernel: [ 8.973444] usbcore: registered new interface driver hiddev
Mar 22 10:58:22 lab709 kernel: [ 8.979008] [drm] Initialized drm 1.1.0 20060810
Mar 22 10:58:22 lab709 kernel: [ 8.985313] ppdev: user-space parallel port driver
Mar 22 10:58:22 lab709 kernel: [ 8.987793] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:1d.3/usb6/6-2/6-2:1.0/input/input3
Mar 22 10:58:22 lab709 kernel: [ 8.987888] generic-usb 0003:046D:C018.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:1d.3-2/input0
Mar 22 10:58:22 lab709 kernel: [ 8.987907] usbcore: registered new interface driver usbhid
Mar 22 10:58:22 lab709 kernel: [ 8.987908] usbhid: USB HID core driver
Mar 22 10:58:22 lab709 kernel: [ 8.991587] type=1400 audit(1300787901.081:2): apparmor="STATUS" operation="profile_load" name="/sbin/dhclient3" pid=635 comm="apparmor_parser"
Mar 22 10:58:22 lab709 kernel: [ 8.991594] type=1400 audit(1300787901.081:3): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient3" pid=623 comm="apparmor_parser"
Mar 22 10:58:22 lab709 kernel: [ 8.992127] type=1400 audit(1300787901.085:4): apparmor="STATUS" operation="profile_load" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=635 comm="apparmor_parser"
Mar 22 10:58:22 lab709 kernel: [ 8.992178] type=1400 audit(1300787901.085:5): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=623 comm="apparmor_parser"
Mar 22 10:58:22 lab709 kernel: [ 8.992421] type=1400 audit(1300787901.085:6): apparmor="STATUS" operation="profile_load" name="/usr/lib/connman/scripts/dhclient-script" pid=635 comm="apparmor_parser"
Mar 22 10:58:22 lab709 kernel: [ 8.992477] type=1400 audit(1300787901.085:7): apparmor="STATUS" operation="profile_replace" name="/usr/lib/connman/scripts/dhclient-script" pid=623 comm="apparmor_parser"
Mar 22 10:58:22 lab709 kernel: [ 9.021946] i915 0000:00:02.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
Mar 22 10:58:22 lab709 kernel: [ 9.040721] lp0: using parport0 (interrupt-driven).
Mar 22 10:58:22 lab709 kernel: [ 9.044172] gspca: main v2.9.0 registered
Mar 22 10:58:22 lab709 kernel: [ 9.045555] [drm] set up 7M of stolen space
Mar 22 10:58:22 lab709 kernel: [ 9.045891] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
Mar 22 10:58:22 lab709 kernel: [ 9.046203] [drm] initialized overlay support
Mar 22 10:58:22 lab709 kernel: [ 9.051987] gspca: probing 041e:4052
Mar 22 10:58:22 lab709 kernel: [ 9.241319] ov519: I2C synced in 0 attempt(s)
Mar 22 10:58:22 lab709 kernel: [ 9.241321] ov519: starting OV7xx0 configuration
Mar 22 10:58:22 lab709 kernel: [ 9.253323] ov519: Sensor is an OV7670
Mar 22 10:58:22 lab709 kernel: [ 9.266144] Console: switching to colour frame buffer device 210x65
Mar 22 10:58:22 lab709 kernel: [ 9.271396] fb0: inteldrmfb frame buffer device
Mar 22 10:58:22 lab709 kernel: [ 9.271398] drm: registered panic notifier
Mar 22 10:58:22 lab709 kernel: [ 9.271401] Slow work thread pool: Starting up
Mar 22 10:58:22 lab709 kernel: [ 9.271443] Slow work thread pool: Ready
Mar 22 10:58:22 lab709 kernel: [ 9.271588] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
Mar 22 10:58:22 lab709 kernel: [ 9.271722] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
Mar 22 10:58:22 lab709 kernel: [ 9.626022] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
Mar 22 10:58:22 lab709 kernel: [ 9.810539] EXT4-fs (sda7): mounted filesystem with ordered data mode. Opts: (null)
Mar 22 10:58:22 lab709 kernel: [ 9.947496] r8169 0000:02:00.0: eth0: link up
Mar 22 10:58:22 lab709 kernel: [ 9.947510] r8169 0000:02:00.0: eth0: link up
Mar 22 10:58:22 lab709 kernel: [ 10.052044] type=1400 audit(1300787902.145:8): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient3" pid=1014 comm="apparmor_parser"
Mar 22 10:58:22 lab709 kernel: [ 10.052598] type=1400 audit(1300787902.145:9): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=1014 comm="apparmor_parser"
Mar 22 10:58:22 lab709 kernel: [ 10.052894] type=1400 audit(1300787902.145:10): apparmor="STATUS" operation="profile_replace" name="/usr/lib/connman/scripts/dhclient-script" pid=1014 comm="apparmor_parser"
Mar 22 10:58:22 lab709 kernel: [ 10.109414] type=1400 audit(1300787902.201:11): apparmor="STATUS" operation="profile_load" name="/usr/share/gdm/guest-session/Xsession" pid=1013 comm="apparmor_parser"
Mar 22 10:58:23 lab709 kernel: [ 10.948392] input: ov519 as /devices/pci0000:00/0000:00:1d.2/usb5/5-1/input/input4
Mar 22 10:58:23 lab709 kernel: [ 10.948476] gspca: video0 created
Mar 22 10:58:23 lab709 kernel: [ 10.948496] usbcore: registered new interface driver ov519
Mar 22 10:58:23 lab709 kernel: [ 10.948498] ov519: registered
Mar 22 10:58:26 lab709 kernel: [ 12.473159] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro,commit=0
Mar 22 10:58:26 lab709 kernel: [ 12.697879] EXT4-fs (sda7): re-mounted. Opts: commit=0
Mar 22 11:03:25 lab709 zmpkg[1921]: INF [Command: status]
Mar 22 11:03:25 lab709 zmpkg[1940]: INF [Command: start]
Mar 22 11:03:25 lab709 zmdc[1949]: INF [Server starting at 11/03/22 11:03:25]
Mar 22 11:03:28 lab709 zmdc[1949]: INF ['zmc -d /dev/video0' starting at 11/03/22 11:03:28, pid = 1971]
Mar 22 11:03:28 lab709 zmdc[1971]: INF ['zmc -d /dev/video0' started at 11/03/22 11:03:28]
Mar 22 11:03:29 lab709 zmc_dvideo0[1971]: INF [Debug Level = 0, Debug Log = <none>]
Mar 22 11:03:29 lab709 zmc_dvideo0[1971]: INF [Starting Capture]
Mar 22 11:03:29 lab709 zmc_dvideo0[1971]: WAR [Hue control is not supported]
Mar 22 11:03:29 lab709 zmdc[1949]: INF ['zma -m 1' starting at 11/03/22 11:03:29, pid = 1974]
Mar 22 11:03:29 lab709 zmdc[1974]: INF ['zma -m 1' started at 11/03/22 11:03:29]
Mar 22 11:03:29 lab709 zma_m1[1974]: INF [Debug Level = 0, Debug Log = <none>]
Mar 22 11:03:29 lab709 zma_m1[1974]: WAR [Waiting for capture daemon]
Mar 22 11:03:29 lab709 zmdc[1949]: INF ['zmfilter.pl' starting at 11/03/22 11:03:29, pid = 1977]
Mar 22 11:03:29 lab709 zmdc[1977]: INF ['zmfilter.pl' started at 11/03/22 11:03:29]
Mar 22 11:03:29 lab709 zmc_dvideo0[1971]: INF [Got signal 11 (Segmentation fault), crashing]
Mar 22 11:03:29 lab709 zmdc[1949]: INF [Starting pending process, zmc -d /dev/video0]
Mar 22 11:03:29 lab709 zmdc[1949]: INF ['zmc -d /dev/video0' starting at 11/03/22 11:03:29, pid = 1979]
Mar 22 11:03:29 lab709 zmdc[1979]: INF ['zmc -d /dev/video0' started at 11/03/22 11:03:29]
Mar 22 11:03:29 lab709 zmc_dvideo0[1979]: INF [Debug Level = 0, Debug Log = <none>]
Mar 22 11:03:29 lab709 zmc_dvideo0[1979]: INF [Starting Capture]
Mar 22 11:03:29 lab709 zmc_dvideo0[1979]: WAR [Hue control is not supported]
Mar 22 11:03:29 lab709 zmdc[1949]: INF ['zmaudit.pl -c' starting at 11/03/22 11:03:29, pid = 1980]
Mar 22 11:03:29 lab709 zmdc[1980]: INF ['zmaudit.pl -c' started at 11/03/22 11:03:29]
Mar 22 11:03:29 lab709 zmdc[1949]: INF ['zmwatch.pl' starting at 11/03/22 11:03:29, pid = 1982]
Mar 22 11:03:29 lab709 zmdc[1982]: INF ['zmwatch.pl' started at 11/03/22 11:03:29]
Mar 22 11:03:29 lab709 zmc_dvideo0[1979]: INF [Got signal 11 (Segmentation fault), crashing]
Mar 22 11:03:29 lab709 zmwatch[1982]: INF [Watchdog starting]
Mar 22 11:03:29 lab709 zmwatch[1982]: INF [Watchdog pausing for 30 seconds]
Mar 22 11:03:29 lab709 zmfilter[1977]: INF [Scanning for events]
Mar 22 11:03:30 lab709 zma_m1[1974]: WAR [Waiting for capture daemon]
Mar 22 11:03:34 lab709 zma_m1[1974]: last message repeated 3 times
Mar 22 11:03:34 lab709 zmdc[1949]: INF [Starting pending process, zmc -d /dev/video0]
Mar 22 11:03:34 lab709 zmdc[1949]: INF ['zmc -d /dev/video0' starting at 11/03/22 11:03:34, pid = 1984]
Mar 22 11:03:34 lab709 zmdc[1984]: INF ['zmc -d /dev/video0' started at 11/03/22 11:03:34]
Mar 22 11:03:34 lab709 zmc_dvideo0[1984]: INF [Debug Level = 0, Debug Log = <none>]
Mar 22 11:03:34 lab709 zmc_dvideo0[1984]: INF [Starting Capture]
Mar 22 11:03:34 lab709 zmc_dvideo0[1984]: WAR [Hue control is not supported]
Mar 22 11:03:34 lab709 zma_m1[1974]: WAR [Waiting for capture daemon]
Mar 22 11:03:34 lab709 zmc_dvideo0[1984]: INF [Got signal 11 (Segmentation fault), crashing]
Mar 22 11:03:35 lab709 zma_m1[1974]: WAR [Waiting for capture daemon]
Mar 22 11:03:37 lab709 zma_m1[1974]: last message repeated 2 times
Mar 22 11:03:37 lab709 zms[1998]: INF [Debug Level = 0, Debug Log = <none>]
Mar 22 11:03:38 lab709 zma_m1[1974]: WAR [Waiting for capture daemon]
Mar 22 11:03:44 lab709 zma_m1[1974]: last message repeated 5 times
Mar 22 11:03:44 lab709 zmdc[1949]: INF [Starting pending process, zmc -d /dev/video0]
Mar 22 11:03:44 lab709 zmdc[1949]: INF ['zmc -d /dev/video0' starting at 11/03/22 11:03:44, pid = 1999]
Mar 22 11:03:44 lab709 zmdc[1999]: INF ['zmc -d /dev/video0' started at 11/03/22 11:03:44]
Mar 22 11:03:44 lab709 zmc_dvideo0[1999]: INF [Debug Level = 0, Debug Log = <none>]
Mar 22 11:03:44 lab709 zmc_dvideo0[1999]: INF [Starting Capture]
Mar 22 11:03:44 lab709 zmc_dvideo0[1999]: WAR [Hue control is not supported]
Mar 22 11:03:44 lab709 zma_m1[1974]: WAR [Waiting for capture daemon]
Mar 22 11:03:44 lab709 zmc_dvideo0[1999]: INF [Got signal 11 (Segmentation fault), crashing]
Mar 22 11:03:45 lab709 zma_m1[1974]: WAR [Waiting for capture daemon]
lab709@lab709:~$
