Geovision GV-800 works in Windows but not Linux (Fedora)
Posted: Sun Mar 27, 2011 10:14 pm
Trying to get a Geovision GM-800 running in Fedora Core 14 with ZM 1.24. I almost constantly get HSYNC errors in /var/log/messages and the camera jumps around a lot. I have tried every possible video type (works best in RGB565). It only seems to be the bttv0 that throws the errors. I know that this isn't a hardware error, as it works perfectly in Windows on the same machine (have formatted it many times, going back/forth between Vista and Fedora), and running it in Windows is not an option.
Any idea what would cause this in Linux? The driver for this has supposedly been in use since about Fedora Core 11 or so. And it does indeed pick up all four BTTV ports on the card successfully in auto-detect (can't remember the card number off the top of my head, I think it's in the 150ish range).
I'm going to try installing Ubuntu now, to see if the same thing happens in that version. I strongly prefer Fedora over Ubuntu, though, so I'm curious as to what is wrong with the configuration. Any info would be appreciated...
