Page 1 of 1
Half display
Posted: Wed Mar 30, 2011 1:18 am
by alexg_ht
I am running ZM on an Ubuntu box with ACTI ACM 4201 camera.
I am only getting half a screen on ZM when displaying the monitor (top half has half the image and the bottom half is black). The camera is set at 640x480 and the only way I can display the half image is if I set ZM at 320x240.
If I use ffplay, then I am getting the full 640x480.
I have been trying to solve this problem for a week now.
Any help would greatly be appreciated. Thanks.
Re: Half display
Posted: Wed Mar 30, 2011 2:42 am
by robert999
What happens if you set the camera and ZM both to 320x240?
Are you seeing a lot of shared memory errors in the zmwatch.log?
Re: Half display
Posted: Wed Mar 30, 2011 2:53 am
by alexg_ht
robert999 wrote:What happens if you set the camera and ZM both to 320x240?
If I set both ZM and camera to 320x240, then I get two small images replicated horizontally on my monitor. But the two images are whole images.
There is no memory error on the zmwatch.log.
Thanks.
Re: Half display
Posted: Wed Mar 30, 2011 2:15 pm
by PacoLM
Could be a crazy idea...change the state of the Options::Config V4L_MULTI_BUFFER value?.
Regards,
PacoLM
Re: Half display
Posted: Tue Nov 22, 2011 4:35 pm
by grndamgt4
Hello, I know this is an old thread but was the issue resolved?
My system has been working without error for almost 2 years and in the last month it started only showing the top 1/4 of the image. It does this both when viewing the camera and when viewing saved events.
I do not remember making any changes.
Thanks all
Re: Half display
Posted: Thu Nov 24, 2011 4:58 pm
by marjanko2
I think i have similar problem, when i plug one camere on my easycap there is normal picture and it works fine, but when I configure camera two on easycap then picture starts to jump like on attachet picture one and two and after a minute i get a screen like on attachet picture three. I have fresh install of ubuntu server 10.10 and zoneminder 1.24.4. And I can't get it work :?
Any solution, please?
Picture 1
Picture 1
Picture 2
Picture 2
Picture 3
Picture 3
Re: Half display
Posted: Thu Nov 24, 2011 11:44 pm
by bb99
Did you disable Options::Config V4L_MULTI_BUFFER value? I'm not familiar with "easycap" but maybe try changing "CAPTURES_PER_FRAME" to a value of 2. Worth a try anyway.
Re: Half display
Posted: Wed Dec 07, 2011 2:05 pm
by marjanko2
Didn't work :cry:
zmwatch.log has an error:
12/07/11 15:03:20.239226 zmwatch[1548].ERR [Shared data size conflict in shared_data for monitor Monitor-1, expected 328, got 316]
12/07/11 15:03:20.241191 zmwatch[1548].ERR [Shared data size conflict in shared_data for monitor Monitor-8, expected 328, got 316]
any idea???
TNX!
Re: Half display
Posted: Thu Dec 08, 2011 3:47 am
by bb99
Ignore my post against your other post. Best I'm going to be able to help with is: http://www.zoneminder.com/forums/search ... mit=Search
Maybe one result will help.
