Intermitten Red Cameras???
Posted: Thu Mar 31, 2011 6:58 pm
I know that this has been asked i have searched.
we changed our ver of zm from 1.23.x to 1.24.2 we are currently running it on mint debian, we ran jaunty before.
The problem:
we have abour 45 cameras connected some will connect (green) then disconnect(red) intermittently.
checked log's
saw the
this are errors after calculating for /etc/sysctl.conf.
this was our sysctl.conf on jaunty also this is based on 50 camera setup running with 8bg mem 640x480.
if can double check or have insight as to why im getting errors i apriciate this thanks. or can this be due to anything else?
ps: we also have a couple of client pc's that connect all day to zm montage to show certain cams.
The problem:
checked log's
saw the
03/29/11 14:37:18.902787 zmwatch[2942].ERR [Can't get shared memory id '7a6d0010', 16: No such file or directory]
03/29/11 14:37:28.911407 zmwatch[2942].ERR [Can't get shared memory id '7a6d0010', 16: No such file or directory]
03/29/11 14:37:38.922528 zmwatch[2942].ERR [Can't get shared memory id '7a6d0010', 16: No such file or directory]
03/29/11 14:37:48.934485 zmwatch[2942].ERR [Can't get shared memory id '7a6d0010', 16: No such file or directory]
03/29/11 14:37:58.947592 zmwatch[2942].ERR [Can't get shared memory id '7a6d0010', 16: No such file or directory]
03/29/11 14:38:08.957710 zmwatch[2942].ERR [Can't get shared memory id '7a6d0010', 16: No such file or directory]
03/29/11 14:38:18.966174 zmwatch[2942].ERR [Can't get shared memory id '7a6d0010', 16: No such file or directory]
03/29/11 14:38:28.975617 zmwatch[2942].ERR [Can't get shared memory id '7a6d0010', 16: No such file or directory]
~ # cat /etc/sysctl.conf|grep kernel.sh*
kernel.shmall = 2048000
kernel.shmmax = 4194304000
