16 CH 480FPS TECHWELL 6805
redcar9
Post by redcar9 »
HI
I have been doing some digging trying to find if this card will work. I see lots of posts that the BT878 chipset works but not very many about the Techwell 6805.
Looking for a card that does 8 channels in real time. Open to suggestions.
New user can't post a link.
Its ebay # 350225210838 from the same seller in the hardware section of this site.
DREMA
Re: 16 CH 480FPS TECHWELL 6805
Post by DREMA »
Yeah, they're now supported by the newest kernel and don't need any configuration. Try booting your system and adding a new camera, also run the command "dmesg" and post the output.
Just... enjoy life! :D
redcar9
Post by redcar9 »
Got the card today. Using an intel atom, ubuntu 10.10 64bit
followed this guide
linux screw 2007/11/05/howto-home-video-security-with-zoneminder-and-ubuntu/
didn't do this command, as I'm not using usb cams
sudo aptitude install gspca-source -y
The web based tool loaded fine. Seem simple to use. I can't get any image from the camera.
redcar9
Post by redcar9 »
0.014054] ... bit width: 40
[ 0.014059] ... generic registers: 2
[ 0.014064] ... value mask: 000000ffffffffff
[ 0.014069] ... max period: 000000007fffffff
[ 0.014074] ... fixed-purpose events: 3
[ 0.014079] ... event mask: 0000000700000003
[ 0.021623] ACPI: Core revision 20100428
[ 0.048078] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.048090] ftrace: allocating 22680 entries in 89 pages
[ 0.050129] Setting APIC routing to flat
[ 0.050549] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.160731] CPU0: Intel(R) Atom(TM) CPU D510 @ 1.66GHz stepping 0a
[ 0.170000] Booting Node 0, Processors #1 #2 #3 Ok.
[ 0.670021] Brought up 4 CPUs
[ 0.670030] Total of 4 processors activated (13333.55 BogoMIPS).
[ 0.671650] devtmpfs: initialized
[ 0.671851] regulator: core version 0.5
[ 0.671898] Time: 23:56:21 Date: 04/14/11
[ 0.671995] NET: Registered protocol family 16
[ 0.672024] Trying to unpack rootfs image as initramfs...
[ 0.672327] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.672336] ACPI: bus type pci registered
[ 0.672513] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.672523] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.693185] PCI: Using configuration type 1 for base access
[ 0.693299] mtrr: your CPUs had inconsistent variable MTRR settings
[ 0.693304] mtrr: probably your BIOS does not setup all CPUs.
[ 0.693308] mtrr: corrected configuration.
[ 0.694987] bio: create slab <bio-0> at 0
[ 0.695461] ACPI: EC: Look up EC in DSDT
[ 0.710442] ACPI: BIOS _OSI(Linux) query ignored
[ 0.714145] ACPI: Interpreter enabled
[ 0.714153] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.714212] ACPI: Using IOAPIC for interrupt routing
[ 0.725991] ACPI: No dock devices found.
[ 0.726003] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.726444] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3f])
[ 0.727325] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7]
[ 0.727333] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff]
[ 0.727341] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.727348] pci_root PNP0A03:00: host bridge window [mem 0xd0000000-0xf7ffffff]
[ 0.727436] pci 0000:00:02.0: reg 10: [mem 0xe0300000-0xe037ffff]
[ 0.727445] pci 0000:00:02.0: reg 14: [io 0x20c0-0x20c7]
[ 0.727454] pci 0000:00:02.0: reg 18: [mem 0xd0000000-0xdfffffff pref]
[ 0.727463] pci 0000:00:02.0: reg 1c: [mem 0xe0200000-0xe02fffff]
[ 0.727580] pci 0000:00:1b.0: reg 10: [mem 0xe0380000-0xe0383fff 64bit]
[ 0.727653] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.727662] pci 0000:00:1b.0: PME# disabled
[ 0.727781] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.727789] pci 0000:00:1c.0: PME# disabled
[ 0.727907] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.727915] pci 0000:00:1c.1: PME# disabled
[ 0.728028] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.728037] pci 0000:00:1c.2: PME# disabled
[ 0.728159] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.728167] pci 0000:00:1c.3: PME# disabled
[ 0.728264] pci 0000:00:1d.0: reg 20: [io 0x2080-0x209f]
[ 0.728360] pci 0000:00:1d.1: reg 20: [io 0x2060-0x207f]
[ 0.728463] pci 0000:00:1d.2: reg 20: [io 0x2040-0x205f]
[ 0.728569] pci 0000:00:1d.3: reg 20: [io 0x2020-0x203f]
[ 0.728651] pci 0000:00:1d.7: reg 10: [mem 0xe0384400-0xe03847ff]
[ 0.728730] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.728739] pci 0000:00:1d.7: PME# disabled
[ 0.728970] pci 0000:00:1f.2: reg 10: [io 0x20b8-0x20bf]
[ 0.728982] pci 0000:00:1f.2: reg 14: [io 0x20cc-0x20cf]
[ 0.728994] pci 0000:00:1f.2: reg 18: [io 0x20b0-0x20b7]
[ 0.729008] pci 0000:00:1f.2: reg 1c: [io 0x20c8-0x20cb]
[ 0.729021] pci 0000:00:1f.2: reg 20: [io 0x20a0-0x20af]
[ 0.729034] pci 0000:00:1f.2: reg 24: [mem 0xe0384000-0xe03843ff]
[ 0.729072] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.729080] pci 0000:00:1f.2: PME# disabled
[ 0.729143] pci 0000:00:1f.3: reg 20: [io 0x2000-0x201f]
[ 0.729306] pci 0000:01:00.0: reg 10: [io 0x1000-0x10ff]
[ 0.729340] pci 0000:01:00.0: reg 18: [mem 0xe0004000-0xe0004fff 64bit pref]
[ 0.729364] pci 0000:01:00.0: reg 20: [mem 0xe0000000-0xe0003fff 64bit pref]
[ 0.729380] pci 0000:01:00.0: reg 30: [mem 0xfffe0000-0xffffffff pref]
[ 0.729443] pci 0000:01:00.0: supports D1 D2
[ 0.729448] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.729458] pci 0000:01:00.0: PME# disabled
[ 0.729503] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.729512] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 0.729522] pci 0000:00:1c.0: bridge window [mem 0xfff00000-0x000fffff] (disabled)
[ 0.729534] pci 0000:00:1c.0: bridge window [mem 0xe0000000-0xe00fffff 64bit pref]
[ 0.729611] pci 0000:00:1c.1: PCI bridge to [bus 02-02]
[ 0.729620] pci 0000:00:1c.1: bridge window [io 0xf000-0x0000] (disabled)
[ 0.729630] pci 0000:00:1c.1: bridge window [mem 0xfff00000-0x000fffff] (disabled)
[ 0.729644] pci 0000:00:1c.1: bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
[ 0.729721] pci 0000:00:1c.2: PCI bridge to [bus 03-03]
[ 0.729730] pci 0000:00:1c.2: bridge window [io 0xf000-0x0000] (disabled)
[ 0.729739] pci 0000:00:1c.2: bridge window [mem 0xfff00000-0x000fffff] (disabled)
[ 0.729751] pci 0000:00:1c.2: bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
[ 0.729820] pci 0000:00:1c.3: PCI bridge to [bus 04-04]
[ 0.729829] pci 0000:00:1c.3: bridge window [io 0xf000-0x0000] (disabled)
[ 0.729842] pci 0000:00:1c.3: bridge window [mem 0xfff00000-0x000fffff] (disabled)
[ 0.729858] pci 0000:00:1c.3: bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
[ 0.730034] pci 0000:05:00.0: supports D1 D2
[ 0.730040] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot
[ 0.730048] pci 0000:05:00.0: PME# disabled
[ 0.730131] pci 0000:00:1e.0: PCI bridge to [bus 05-06] (subtractive decode)
[ 0.730141] pci 0000:00:1e.0: bridge window [io 0xf000-0x0000] (disabled)
[ 0.730150] pci 0000:00:1e.0: bridge window [mem 0xe0100000-0xe01fffff]
[ 0.730163] pci 0000:00:1e.0: bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
[ 0.730170] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.730177] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.730184] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.730191] pci 0000:00:1e.0: bridge window [mem 0xd0000000-0xf7ffffff] (subtractive decode)
[ 0.730322] pci 0000:06:04.0: reg 10: [mem 0xe0101c00-0xe0101fff]
[ 0.730480] pci 0000:06:04.1: reg 10: [mem 0xe0102380-0xe01023ff]
[ 0.730652] pci 0000:06:05.0: reg 10: [mem 0xe0101800-0xe0101bff]
[ 0.730808] pci 0000:06:05.1: reg 10: [mem 0xe0102300-0xe010237f]
[ 0.730978] pci 0000:06:06.0: reg 10: [mem 0xe0101400-0xe01017ff]
[ 0.731135] pci 0000:06:06.1: reg 10: [mem 0xe0102280-0xe01022ff]
[ 0.731317] pci 0000:06:07.0: reg 10: [mem 0xe0101000-0xe01013ff]
[ 0.731473] pci 0000:06:07.1: reg 10: [mem 0xe0102200-0xe010227f]
[ 0.731645] pci 0000:06:08.0: reg 10: [mem 0xe0100c00-0xe0100fff]
[ 0.731802] pci 0000:06:08.1: reg 10: [mem 0xe0102180-0xe01021ff]
[ 0.731971] pci 0000:06:09.0: reg 10: [mem 0xe0100800-0xe0100bff]
[ 0.732127] pci 0000:06:09.1: reg 10: [mem 0xe0102100-0xe010217f]
[ 0.732299] pci 0000:06:0a.0: reg 10: [mem 0xe0100400-0xe01007ff]
[ 0.732458] pci 0000:06:0a.1: reg 10: [mem 0xe0102080-0xe01020ff]
[ 0.732636] pci 0000:06:0b.0: reg 10: [mem 0xe0100000-0xe01003ff]
[ 0.732790] pci 0000:06:0b.1: reg 10: [mem 0xe0102000-0xe010207f]
[ 0.732973] pci 0000:05:00.0: PCI bridge to [bus 06-06]
[ 0.732985] pci 0000:05:00.0: bridge window [io 0xfffffffffffff000-0x0000] (disabled)
[ 0.732996] pci 0000:05:00.0: bridge window [mem 0xe0100000-0xe01fffff]
[ 0.733009] pci 0000:05:00.0: bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
[ 0.733071] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.733482] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P32_._PRT]
[ 0.733967] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX0._PRT]
[ 0.734133] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX1._PRT]
[ 0.734300] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX2._PRT]
[ 0.734465] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX3._PRT]
[ 0.746031] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 9 10 *11 12)
[ 0.746281] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[ 0.746541] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 *9 10 11 12)
[ 0.746789] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 10 *11 12)
[ 0.747033] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 10 *11 12)
[ 0.747279] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 *10 11 12)
[ 0.747525] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 *9 10 11 12)
[ 0.747771] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 9 *10 11 12)
[ 0.747881] HEST: Table is not found!
redcar9
Post by redcar9 »
0.748088] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.748136] vgaarb: loaded
[ 0.748505] SCSI subsystem initialized
[ 0.748557] libata version 3.00 loaded.
[ 0.748557] usbcore: registered new interface driver usbfs
[ 0.748557] usbcore: registered new interface driver hub
[ 0.748557] usbcore: registered new device driver usb
[ 0.748557] ACPI: WMI: Mapper loaded
[ 0.748557] PCI: Using ACPI for IRQ routing
[ 0.748557] PCI: pci_cache_line_size set to 64 bytes
[ 0.748557] reserve RAM buffer: 000000000008f000 - 000000000008ffff
[ 0.748557] reserve RAM buffer: 000000000009ec00 - 000000000009ffff
[ 0.748557] reserve RAM buffer: 000000007ee98000 - 000000007fffffff
[ 0.748557] reserve RAM buffer: 000000007ef48000 - 000000007fffffff
[ 0.750014] reserve RAM buffer: 000000007eff1000 - 000000007fffffff
[ 0.750022] reserve RAM buffer: 000000007f000000 - 000000007fffffff
[ 0.750269] NetLabel: Initializing
[ 0.750275] NetLabel: domain hash size = 128
[ 0.750279] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.750313] NetLabel: unlabeled traffic allowed by default
[ 0.750414] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.750425] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.750436] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.780324] Switching to clocksource tsc
[ 0.804127] AppArmor: AppArmor Filesystem Enabled
[ 0.804168] pnp: PnP ACPI init
[ 0.804216] ACPI: bus type pnp registered
[ 0.809076] pnp: PnP ACPI: found 13 devices
[ 0.809083] ACPI: ACPI bus type pnp unregistered
[ 0.809114] system 00:01: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.809122] system 00:01: [mem 0xfed14000-0xfed17fff] has been reserved
[ 0.809130] system 00:01: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.809137] system 00:01: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.809144] system 00:01: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.809152] system 00:01: [mem 0x000c0000-0x000dffff] has been reserved
[ 0.809159] system 00:01: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.809167] system 00:01: [mem 0xfff00000-0xffffffff] has been reserved
[ 0.809185] system 00:06: [io 0x0500-0x053f] has been reserved
[ 0.809193] system 00:06: [io 0x0400-0x047f] has been reserved
[ 0.809200] system 00:06: [io 0x0680-0x06ff] has been reserved
[ 0.809208] system 00:06: [io 0x0295-0x0296] has been reserved
[ 0.821432] pci 0000:01:00.0: no compatible bridge window for [mem 0xfffe0000-0xffffffff pref]
[ 0.821576] pci 0000:00:1c.0: BAR 14: assigned [mem 0xe0400000-0xe07fffff]
[ 0.821585] pci 0000:00:1c.1: BAR 14: assigned [mem 0xe0800000-0xe09fffff]
[ 0.821594] pci 0000:00:1c.1: BAR 15: assigned [mem 0xe0a00000-0xe0bfffff 64bit pref]
[ 0.821602] pci 0000:00:1c.2: BAR 14: assigned [mem 0xe0c00000-0xe0dfffff]
[ 0.821610] pci 0000:00:1c.2: BAR 15: assigned [mem 0xe0e00000-0xe0ffffff 64bit pref]
[ 0.821618] pci 0000:00:1c.3: BAR 14: assigned [mem 0xe1000000-0xe11fffff]
[ 0.821627] pci 0000:00:1c.3: BAR 15: assigned [mem 0xe1200000-0xe13fffff 64bit pref]
[ 0.821637] pci 0000:00:1c.1: BAR 13: assigned [io 0x3000-0x3fff]
[ 0.821645] pci 0000:00:1c.2: BAR 13: assigned [io 0x4000-0x4fff]
[ 0.821653] pci 0000:00:1c.3: BAR 13: assigned [io 0x5000-0x5fff]
[ 0.821661] pci 0000:01:00.0: BAR 6: assigned [mem 0xe0020000-0xe003ffff pref]
[ 0.821670] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.821677] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 0.821688] pci 0000:00:1c.0: bridge window [mem 0xe0400000-0xe07fffff]
[ 0.821698] pci 0000:00:1c.0: bridge window [mem 0xe0000000-0xe00fffff 64bit pref]
[ 0.821711] pci 0000:00:1c.1: PCI bridge to [bus 02-02]
[ 0.821719] pci 0000:00:1c.1: bridge window [io 0x3000-0x3fff]
[ 0.821729] pci 0000:00:1c.1: bridge window [mem 0xe0800000-0xe09fffff]
[ 0.821739] pci 0000:00:1c.1: bridge window [mem 0xe0a00000-0xe0bfffff 64bit pref]
[ 0.821752] pci 0000:00:1c.2: PCI bridge to [bus 03-03]
[ 0.821759] pci 0000:00:1c.2: bridge window [io 0x4000-0x4fff]
[ 0.821770] pci 0000:00:1c.2: bridge window [mem 0xe0c00000-0xe0dfffff]
[ 0.821780] pci 0000:00:1c.2: bridge window [mem 0xe0e00000-0xe0ffffff 64bit pref]
[ 0.821793] pci 0000:00:1c.3: PCI bridge to [bus 04-04]
[ 0.821799] pci 0000:00:1c.3: bridge window [io 0x5000-0x5fff]
[ 0.821810] pci 0000:00:1c.3: bridge window [mem 0xe1000000-0xe11fffff]
[ 0.821820] pci 0000:00:1c.3: bridge window [mem 0xe1200000-0xe13fffff 64bit pref]
[ 0.821838] pci 0000:05:00.0: PCI bridge to [bus 06-06]
[ 0.821843] pci 0000:05:00.0: bridge window [io disabled]
[ 0.821853] pci 0000:05:00.0: bridge window [mem 0xe0100000-0xe01fffff]
[ 0.821862] pci 0000:05:00.0: bridge window [mem pref disabled]
[ 0.821874] pci 0000:00:1e.0: PCI bridge to [bus 05-06]
[ 0.821879] pci 0000:00:1e.0: bridge window [io disabled]
[ 0.821889] pci 0000:00:1e.0: bridge window [mem 0xe0100000-0xe01fffff]
[ 0.821897] pci 0000:00:1e.0: bridge window [mem pref disabled]
[ 0.821930] alloc irq_desc for 17 on node -1
[ 0.821936] alloc kstat_irqs on node -1
[ 0.821952] pci 0000:00:1c.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 0.821962] pci 0000:00:1c.0: setting latency timer to 64
[ 0.821979] pci 0000:00:1c.1: enabling device (0000 -> 0003)
[ 0.821987] alloc irq_desc for 16 on node -1
[ 0.821991] alloc kstat_irqs on node -1
[ 0.822002] pci 0000:00:1c.1: PCI INT B -> GSI 16 (level, low) -> IRQ 16
[ 0.822013] pci 0000:00:1c.1: setting latency timer to 64
[ 0.822028] pci 0000:00:1c.2: enabling device (0000 -> 0003)
[ 0.822036] alloc irq_desc for 18 on node -1
[ 0.822041] alloc kstat_irqs on node -1
[ 0.822050] pci 0000:00:1c.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 0.822061] pci 0000:00:1c.2: setting latency timer to 64
[ 0.822077] pci 0000:00:1c.3: enabling device (0000 -> 0003)
[ 0.822085] alloc irq_desc for 19 on node -1
[ 0.822089] alloc kstat_irqs on node -1
[ 0.822099] pci 0000:00:1c.3: PCI INT D -> GSI 19 (level, low) -> IRQ 19
[ 0.822110] pci 0000:00:1c.3: setting latency timer to 64
[ 0.822125] pci 0000:00:1e.0: setting latency timer to 64
[ 0.822144] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.822151] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.822157] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.822163] pci_bus 0000:00: resource 7 [mem 0xd0000000-0xf7ffffff]
[ 0.822169] pci_bus 0000:01: resource 0 [io 0x1000-0x1fff]
[ 0.822175] pci_bus 0000:01: resource 1 [mem 0xe0400000-0xe07fffff]
[ 0.822182] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xe00fffff 64bit pref]
[ 0.822189] pci_bus 0000:02: resource 0 [io 0x3000-0x3fff]
[ 0.822195] pci_bus 0000:02: resource 1 [mem 0xe0800000-0xe09fffff]
[ 0.822201] pci_bus 0000:02: resource 2 [mem 0xe0a00000-0xe0bfffff 64bit pref]
[ 0.822208] pci_bus 0000:03: resource 0 [io 0x4000-0x4fff]
[ 0.822213] pci_bus 0000:03: resource 1 [mem 0xe0c00000-0xe0dfffff]
[ 0.822220] pci_bus 0000:03: resource 2 [mem 0xe0e00000-0xe0ffffff 64bit pref]
[ 0.822226] pci_bus 0000:04: resource 0 [io 0x5000-0x5fff]
[ 0.822232] pci_bus 0000:04: resource 1 [mem 0xe1000000-0xe11fffff]
[ 0.822239] pci_bus 0000:04: resource 2 [mem 0xe1200000-0xe13fffff 64bit pref]
[ 0.822246] pci_bus 0000:05: resource 1 [mem 0xe0100000-0xe01fffff]
[ 0.822252] pci_bus 0000:05: resource 4 [io 0x0000-0x0cf7]
[ 0.822258] pci_bus 0000:05: resource 5 [io 0x0d00-0xffff]
[ 0.822264] pci_bus 0000:05: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.822270] pci_bus 0000:05: resource 7 [mem 0xd0000000-0xf7ffffff]
[ 0.822277] pci_bus 0000:06: resource 1 [mem 0xe0100000-0xe01fffff]
[ 0.822365] NET: Registered protocol family 2
[ 0.822634] IP route cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.824233] TCP established hash table entries: 262144 (order: 10, 4194304 bytes)
[ 0.827815] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.828682] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.828689] TCP reno registered
[ 0.828721] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.828763] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.829095] NET: Registered protocol family 1
[ 0.829142] pci 0000:00:02.0: Boot video device
[ 0.848966] PCI: CLS 64 bytes, default 64
[ 0.849719] Scanning for low memory corruption every 60 seconds
[ 0.850099] audit: initializing netlink socket (disabled)
[ 0.850132] type=2000 audit(1302825380.840:1): initialized
[ 0.875158] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.878828] VFS: Disk quotas dquot_6.5.2
[ 0.879027] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.880577] fuse init (API version 7.14)
[ 0.880815] msgmni has been set to 3957
[ 0.881711] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.881720] io scheduler noop registered
[ 0.881725] io scheduler deadline registered
[ 0.881831] io scheduler cfq registered (default)
[ 0.882149] pcieport 0000:00:1c.0: setting latency timer to 64
[ 0.882211] alloc irq_desc for 40 on node -1
[ 0.882216] alloc kstat_irqs on node -1
[ 0.882238] pcieport 0000:00:1c.0: irq 40 for MSI/MSI-X
[ 0.882424] pcieport 0000:00:1c.1: setting latency timer to 64
[ 0.882480] alloc irq_desc for 41 on node -1
[ 0.882484] alloc kstat_irqs on node -1
[ 0.882500] pcieport 0000:00:1c.1: irq 41 for MSI/MSI-X
[ 0.882677] pcieport 0000:00:1c.2: setting latency timer to 64
[ 0.882733] alloc irq_desc for 42 on node -1
[ 0.882738] alloc kstat_irqs on node -1
[ 0.882754] pcieport 0000:00:1c.2: irq 42 for MSI/MSI-X
[ 0.882930] pcieport 0000:00:1c.3: setting latency timer to 64
[ 0.882986] alloc irq_desc for 43 on node -1
[ 0.882990] alloc kstat_irqs on node -1
[ 0.883006] pcieport 0000:00:1c.3: irq 43 for MSI/MSI-X
[ 0.883264] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.883498] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.883711] intel_idle: MWAIT substates: 0x10
[ 0.883717] intel_idle: v0.4 model 0x1C
[ 0.883721] intel_idle: lapic_timer_reliable_states 0x6
[ 0.883978] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 0.884000] ACPI: Sleep Button [SLPB]
[ 0.884120] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.884130] ACPI: Power Button [PWRF]
[ 0.884505] ACPI: acpi_idle yielding to intel_idle
[ 0.890457] ERST: Table is not found!
[ 0.890931] Linux agpgart interface v0.103
[ 0.891021] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.891218] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.891426] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.892140] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.892454] 00:0a: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.896550] brd: module loaded
[ 0.898451] loop: module loaded
[ 0.899170] ata_piix 0000:00:1f.2: version 2.13
[ 0.899211] ata_piix 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 0.899225] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.063837] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.064068] scsi0 : ata_piix
[ 1.064362] scsi1 : ata_piix
[ 1.064944] ata1: SATA max UDMA/133 cmd 0x20b8 ctl 0x20cc bmdma 0x20a0 irq 19
[ 1.064955] ata2: SATA max UDMA/133 cmd 0x20b0 ctl 0x20c8 bmdma 0x20a8 irq 19
[ 1.065928] Fixed MDIO Bus: probed
[ 1.066016] PPP generic driver version 2.4.2
[ 1.066150] tun: Universal TUN/TAP device driver, 1.6
[ 1.066156] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.066371] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.066424] alloc irq_desc for 23 on node -1
[ 1.066429] alloc kstat_irqs on node -1
[ 1.066446] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 1.066488] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.066496] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.066597] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 1.066637] ehci_hcd 0000:00:1d.7: using broken periodic workaround
[ 1.066655] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.070532] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 1.070571] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xe0384400
[ 1.093769] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.094096] hub 1-0:1.0: USB hub found
[ 1.094110] hub 1-0:1.0: 8 ports detected
[ 1.094306] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.094351] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.094501] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 1.094518] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.094526] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.094658] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.094699] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00002080
[ 1.095000] hub 2-0:1.0: USB hub found
[ 1.095014] hub 2-0:1.0: 2 ports detected
[ 1.095176] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 1.095190] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.095197] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.095292] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 1.095331] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00002060
[ 1.095613] hub 3-0:1.0: USB hub found
[ 1.095625] hub 3-0:1.0: 2 ports detected
[ 1.095776] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 1.095789] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.095796] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.095896] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 1.095961] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00002040
[ 1.096259] hub 4-0:1.0: USB hub found
[ 1.096283] hub 4-0:1.0: 2 ports detected
[ 1.096440] uhci_hcd 0000:00:1d.3: PCI INT D -> GSI 16 (level, low) -> IRQ 16
[ 1.096453] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 1.096460] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.096555] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 1.096614] uhci_hcd 0000:00:1d.3: irq 16, io base 0x00002020
[ 1.096910] hub 5-0:1.0: USB hub found
[ 1.096922] hub 5-0:1.0: 2 ports detected
[ 1.097191] PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 1.097196] PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.097918] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.098125] mice: PS/2 mouse device common for all mice
[ 1.098408] rtc_cmos 00:03: RTC can wake from S4
[ 1.098521] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 1.098565] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 1.098838] device-mapper: uevent: version 1.0.3
[ 1.099131] device-mapper: ioctl: 4.17.0-ioctl (2010-03-05) initialised: dm-devel@redhat.com
[ 1.099513] device-mapper: multipath: version 1.1.1 loaded
[ 1.099522] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 1.100446] cpuidle: using governor ladder
[ 1.100681] cpuidle: using governor menu
[ 1.101358] TCP cubic registered
[ 1.101698] NET: Registered protocol family 10
[ 1.102621] lo: Disabled Privacy Extensions
[ 1.103143] NET: Registered protocol family 17
[ 1.104033] ACPI Exception: AE_NOT_FOUND, Evaluating _PSS (20100428/processor_perflib-322)
[ 1.104113] ACPI Exception: AE_NOT_FOUND, Evaluating _PSS (20100428/processor_perflib-322)
[ 1.104189] ACPI Exception: AE_NOT_FOUND, Evaluating _PSS (20100428/processor_perflib-322)
[ 1.104264] ACPI Exception: AE_NOT_FOUND, Evaluating _PSS (20100428/processor_perflib-322)
[ 1.104528] PM: Resume from disk failed.
[ 1.104556] registered taskstats version 1
[ 1.105390] Magic number: 7:371:959
[ 1.105558] rtc_cmos 00:03: setting system clock to 2011-04-14 23:56:21 UTC (1302825381)
[ 1.105566] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 1.105570] EDD information not available.
[ 1.116849] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[ 1.201439] Freeing initrd memory: 10740k freed
[ 1.241491] ata1.00: ATA-8: ST9250320AS, HP07, max UDMA/100
[ 1.241500] ata1.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.281508] ata1.00: configured for UDMA/100
[ 1.281801] scsi 0:0:0:0: Direct-Access ATA ST9250320AS HP07 PQ: 0 ANSI: 5
[ 1.282156] sd 0:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[ 1.282223] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.282399] sd 0:0:0:0: [sda] Write Protect is off
[ 1.282410] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.282492] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.282922] sda: sda1 sda2 < sda5 >
[ 1.332982] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.333036] Freeing unused kernel memory: 908k freed
[ 1.333532] Write protecting the kernel read-only data: 10240k
[ 1.333976] Freeing unused kernel memory: 416k freed
[ 1.334651] Freeing unused kernel memory: 1644k freed
[ 1.378927] udev[102]: starting version 163
[ 1.518928] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.518985] r8169 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.519075] r8169 0000:01:00.0: setting latency timer to 64
[ 1.519154] alloc irq_desc for 44 on node -1
[ 1.519161] alloc kstat_irqs on node -1
[ 1.519194] r8169 0000:01:00.0: irq 44 for MSI/MSI-X
[ 1.521025] r8169 0000:01:00.0: eth0: RTL8168d/8111d at 0xffffc90000348000, 00:27:0e:04:59:cb, XID 081000c0 IRQ 44
[ 1.631299] usb 3-2: new low speed USB device using uhci_hcd and address 2
[ 1.850697] usbcore: registered new interface driver hiddev
[ 1.864852] input: Microsoft Basic Optical Mouse as /devices/pci0000:00/0000:00:1d.1/usb3/3-2/3-2:1.0/input/input3
[ 1.865230] generic-usb 0003:045E:0084.0001: input,hidraw0: USB HID v1.10 Mouse [Microsoft Basic Optical Mouse] on usb-0000:00:1d.1-2/input0
[ 1.865312] usbcore: registered new interface driver usbhid
[ 1.865320] usbhid: USB HID core driver
[ 1.946821] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 4.751816] Adding 5972988k swap on /dev/sda5. Priority:-1 extents:1 across:5972988k
[ 5.540600] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 5.670345] udev[322]: starting version 163
[ 8.448975] type=1400 audit(1302825388.827:2): apparmor="STATUS" operation="profile_load" name="/sbin/dhclient3" pid=485 comm="apparmor_parser"
[ 8.449542] type=1400 audit(1302825388.827:3): apparmor="STATUS" operation="profile_load" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=485 comm="apparmor_parser"
[ 8.449869] type=1400 audit(1302825388.827:4): apparmor="STATUS" operation="profile_load" name="/usr/lib/connman/scripts/dhclient-script" pid=485 comm="apparmor_parser"
[ 8.708208] agpgart-intel 0000:00:00.0: Intel GMA3150 Chipset
[ 8.709079] agpgart-intel 0000:00:00.0: detected 8188K stolen memory
[ 8.722221] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xd0000000
[ 8.786624] lp: driver loaded but no devices found
redcar9
Post by redcar9 »
[ 9.168567] parport_pc 00:08: reported by Plug and Play ACPI
[ 9.168641] parport0: PC-style at 0x378, irq 7 [PCSPP]
[ 9.241565] lp0: using parport0 (interrupt-driven).
[ 9.306670] ppdev: user-space parallel port driver
[ 9.403034] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 9.758695] [drm] Initialized drm 1.1.0 20060810
[ 10.294293] i915 0000:00:02.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 10.294305] i915 0000:00:02.0: setting latency timer to 64
[ 10.393686] alloc irq_desc for 45 on node -1
[ 10.393695] alloc kstat_irqs on node -1
[ 10.393714] i915 0000:00:02.0: irq 45 for MSI/MSI-X
[ 10.393737] [drm] set up 7M of stolen space
[ 10.394609] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 10.395035] [drm] initialized overlay support
[ 10.747931] Console: switching to colour frame buffer device 160x64
[ 10.762436] fb0: inteldrmfb frame buffer device
[ 10.762443] drm: registered panic notifier
[ 10.762453] Slow work thread pool: Starting up
[ 10.762617] Slow work thread pool: Ready
[ 10.762739] No ACPI video bus found
[ 10.763071] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 13.661758] alloc irq_desc for 22 on node -1
[ 13.661769] alloc kstat_irqs on node -1
[ 13.661792] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 13.661991] alloc irq_desc for 46 on node -1
[ 13.661999] alloc kstat_irqs on node -1
[ 13.662026] HDA Intel 0000:00:1b.0: irq 46 for MSI/MSI-X
[ 13.662089] HDA Intel 0000:00:1b.0: setting latency timer to 64
[ 13.888958] hda_codec: ALC662 rev1: BIOS auto-probing.
[ 14.146670] type=1400 audit(1302825394.527:5): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient3" pid=727 comm="apparmor_parser"
[ 14.147249] type=1400 audit(1302825394.527:6): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=727 comm="apparmor_parser"
[ 14.147585] type=1400 audit(1302825394.527:7): apparmor="STATUS" operation="profile_replace" name="/usr/lib/connman/scripts/dhclient-script" pid=727 comm="apparmor_parser"
[ 14.542235] type=1400 audit(1302825394.927:8): apparmor="STATUS" operation="profile_load" name="/usr/share/gdm/guest-session/Xsession" pid=726 comm="apparmor_parser"
[ 14.551577] type=1400 audit(1302825394.937:9): apparmor="STATUS" operation="profile_load" name="/usr/sbin/tcpdump" pid=731 comm="apparmor_parser"
[ 14.703676] type=1400 audit(1302825395.087:10): apparmor="STATUS" operation="profile_load" name="/usr/lib/cups/backend/cups-pdf" pid=730 comm="apparmor_parser"
[ 14.704526] type=1400 audit(1302825395.097:11): apparmor="STATUS" operation="profile_load" name="/usr/sbin/cupsd" pid=730 comm="apparmor_parser"
[ 15.041033] type=1400 audit(1302825395.427:12): apparmor="STATUS" operation="profile_load" name="/usr/bin/evince" pid=728 comm="apparmor_parser"
[ 15.048107] type=1400 audit(1302825395.437:13): apparmor="STATUS" operation="profile_load" name="/usr/bin/evince-previewer" pid=728 comm="apparmor_parser"
[ 15.053029] type=1400 audit(1302825395.437:14): apparmor="STATUS" operation="profile_load" name="/usr/bin/evince-thumbnailer" pid=728 comm="apparmor_parser"
[ 20.509619] r8169 0000:01:00.0: eth0: link up
[ 20.509644] r8169 0000:01:00.0: eth0: link up
[ 28.968415] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro,commit=0
[ 31.321261] eth0: no IPv6 routers present
[ 47.175906] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro,commit=0
[ 169.890033] usb 1-1: new high speed USB device using ehci_hcd and address 3
[ 170.148431] Initializing USB Mass Storage driver...
[ 170.148802] scsi2 : usb-storage 1-1:1.0
[ 170.149745] usbcore: registered new interface driver usb-storage
[ 170.149755] USB Mass Storage support registered.
[ 171.140917] scsi 2:0:0:0: Direct-Access SanDisk Cruzer Micro 0.1 PQ: 0 ANSI: 2
[ 171.142490] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 171.144053] sd 2:0:0:0: [sdb] 501759 512-byte logical blocks: (256 MB/244 MiB)
[ 171.144676] sd 2:0:0:0: [sdb] Write Protect is off
[ 171.144689] sd 2:0:0:0: [sdb] Mode Sense: 03 00 00 00
[ 171.144698] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 171.150400] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 171.150419] sdb: sdb1
[ 171.155152] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 171.155169] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[ 1015.152145] type=1400 audit(1302826395.536:15): apparmor="STATUS" operation="profile_load" name="/usr/sbin/mysqld" pid=8714 comm="apparmor_parser"
[ 1015.259130] type=1400 audit(1302826395.646:16): apparmor="STATUS" operation="profile_replace" name="/usr/sbin/mysqld" pid=8718 comm="apparmor_parser"
cctv@cctv-desktop:~$ dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.35-22-generic (buildd@allspice) (gcc version 4.4.5 (Ubuntu/Linaro 4.4.4-14ubuntu4) ) #33-Ubuntu SMP Sun Sep 19 20:32:27 UTC 2010 (Ubuntu 2.6.35-22.33-generic 2.6.35.4)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-2.6.35-22-generic root=UUID=a5b13f38-0e45-4181-914d-4993f8aa6b90 ro quiet splash
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000008f000 (usable)
[ 0.000000] BIOS-e820: 000000000008f000 - 0000000000090000 (reserved)
[ 0.000000] BIOS-e820: 0000000000090000 - 000000000009ec00 (usable)
[ 0.000000] BIOS-e820: 000000000009ec00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007ee98000 (usable)
[ 0.000000] BIOS-e820: 000000007ee98000 - 000000007eebf000 (reserved)
[ 0.000000] BIOS-e820: 000000007eebf000 - 000000007ef48000 (usable)
[ 0.000000] BIOS-e820: 000000007ef48000 - 000000007efbf000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007efbf000 - 000000007eff1000 (usable)
[ 0.000000] BIOS-e820: 000000007eff1000 - 000000007efff000 (ACPI data)
[ 0.000000] BIOS-e820: 000000007efff000 - 000000007f000000 (usable)
[ 0.000000] BIOS-e820: 000000007f000000 - 0000000080000000 (reserved)
[ 0.000000] BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] DMI 2.5 present.
[ 0.000000] e820 update range: 0000000000000000 - 0000000000001000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] No AGP bridge found
[ 0.000000] last_pfn = 0x7f000 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-DFFFF write-protect
[ 0.000000] E0000-FFFFF uncachable
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 base 07F000000 mask FFF000000 uncachable
[ 0.000000] 2 base 0FFFF0000 mask FFFFF0000 write-protect
[ 0.000000] 3 base 0FFF10000 mask FFFFF0000 write-protect
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 0000000000001000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000010000 (reserved)
[ 0.000000] modified: 0000000000010000 - 000000000008f000 (usable)
[ 0.000000] modified: 000000000008f000 - 0000000000090000 (reserved)
[ 0.000000] modified: 0000000000090000 - 000000000009ec00 (usable)
[ 0.000000] modified: 000000000009ec00 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 000000007ee98000 (usable)
[ 0.000000] modified: 000000007ee98000 - 000000007eebf000 (reserved)
[ 0.000000] modified: 000000007eebf000 - 000000007ef48000 (usable)
[ 0.000000] modified: 000000007ef48000 - 000000007efbf000 (ACPI NVS)
[ 0.000000] modified: 000000007efbf000 - 000000007eff1000 (usable)
[ 0.000000] modified: 000000007eff1000 - 000000007efff000 (ACPI data)
[ 0.000000] modified: 000000007efff000 - 000000007f000000 (usable)
[ 0.000000] modified: 000000007f000000 - 0000000080000000 (reserved)
[ 0.000000] modified: 00000000f8000000 - 00000000fc000000 (reserved)
[ 0.000000] modified: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] initial memory mapped : 0 - 20000000
[ 0.000000] found SMP MP-table at [ffff8800000fbe70] fbe70
[ 0.000000] init_memory_mapping: 0000000000000000-000000007f000000
[ 0.000000] 0000000000 - 007f000000 page 2M
[ 0.000000] kernel direct mapping tables up to 7f000000 @ 16000-19000
[ 0.000000] RAMDISK: 37573000 - 37ff0000
[ 0.000000] ACPI: RSDP 00000000000f2110 00024 (v02 INTEL )
[ 0.000000] ACPI: XSDT 000000007effe120 0004C (v01 INTEL MOPNV10N 000001F5 01000013)
[ 0.000000] ACPI: FACP 000000007effd000 000F4 (v03 INTEL MOPNV10N 000001F5 MSFT 0100000D)
[ 0.000000] ACPI: DSDT 000000007eff9000 039A7 (v01 INTEL MOPNV10N 000001F5 MSFT 0100000D)
[ 0.000000] ACPI: FACS 000000007ef87000 00040
[ 0.000000] ACPI: APIC 000000007eff8000 00084 (v02 INTEL MOPNV10N 000001F5 MSFT 0100000D)
[ 0.000000] ACPI: MCFG 000000007eff7000 0003C (v01 INTEL MOPNV10N 000001F5 MSFT 0100000D)
[ 0.000000] ACPI: HPET 000000007eff6000 00038 (v01 INTEL MOPNV10N 000001F5 MSFT 0100000D)
[ 0.000000] ACPI: SSDT 000000007eff2000 0377C (v01 INTEL SSDT PM 000001F5 MSFT 0100000D)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at 0000000000000000-000000007f000000
[ 0.000000] Initmem setup node 0 0000000000000000-000000007f000000
[ 0.000000] NODE_DATA [0000000001d181c0 - 0000000001d1d1bf]
[ 0.000000] [ffffea0000000000-ffffea0001bfffff] PMD -> [ffff880002600000-ffff8800041fffff] on node 0
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] DMA32 0x00001000 -> 0x00100000
[ 0.000000] Normal empty
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[6] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000008f
[ 0.000000] 0: 0x00000090 -> 0x0000009e
[ 0.000000] 0: 0x00000100 -> 0x0007ee98
[ 0.000000] 0: 0x0007eebf -> 0x0007ef48
[ 0.000000] 0: 0x0007efbf -> 0x0007eff1
[ 0.000000] 0: 0x0007efff -> 0x0007f000
[ 0.000000] On node 0 totalpages: 519905
[ 0.000000] DMA zone: 56 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3925 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 7056 pages used for memmap
[ 0.000000] DMA32 zone: 508868 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high level lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high level lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high level lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x04] high level lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] early_res array is doubled to 64 at [17000 - 177ff]
[ 0.000000] PM: Registered nosave memory: 000000000008f000 - 0000000000090000
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 000000000009f000
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] PM: Registered nosave memory: 000000007ee98000 - 000000007eebf000
[ 0.000000] PM: Registered nosave memory: 000000007ef48000 - 000000007efbf000
[ 0.000000] PM: Registered nosave memory: 000000007eff1000 - 000000007efff000
[ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:78000000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:64 nr_cpumask_bits:64 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 30 pages/cpu @ffff880001e00000 s91520 r8192 d23168 u524288
[ 0.000000] pcpu-alloc: s91520 r8192 d23168 u524288 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3
[ 0.000000] early_res array is doubled to 128 at [17800 - 187ff]
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 512793
[ 0.000000] Policy zone: DMA32
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.35-22-generic root=UUID=a5b13f38-0e45-4181-914d-4993f8aa6b90 ro quiet splash
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Checking aperture...
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Subtract (57 early reservations)
[ 0.000000] #1 [0001000000 - 0001d17114] TEXT DATA BSS
[ 0.000000] #2 [0037573000 - 0037ff0000] RAMDISK
[ 0.000000] #3 [0001d18000 - 0001d1819e] BRK
[ 0.000000] #4 [000009ec00 - 00000fbe70] BIOS reserved
[ 0.000000] #5 [00000fbe70 - 00000fbe80] MP-table mpf
[ 0.000000] #6 [00000fbec0 - 0000100000] BIOS reserved
[ 0.000000] #7 [00000fbe80 - 00000fbec0] MP-table mpc
[ 0.000000] #8 [0000010000 - 0000012000] TRAMPOLINE
[ 0.000000] #9 [0000012000 - 0000016000] ACPI WAKEUP
[ 0.000000] #10 [0000016000 - 0000017000] PGTABLE
[ 0.000000] #11 [0001d181c0 - 0001d1d1c0] NODE_DATA
[ 0.000000] #12 [0001d1d1c0 - 0001d1e1c0] BOOTMEM
[ 0.000000] #13 [0001d17140 - 0001d172c0] BOOTMEM
[ 0.000000] #14 [000251f000 - 0002520000] BOOTMEM
[ 0.000000] #15 [0002520000 - 0002521000] BOOTMEM
[ 0.000000] #16 [0002600000 - 0004200000] MEMMAP 0
[ 0.000000] #17 [0001d172c0 - 0001d17440] BOOTMEM
[ 0.000000] #18 [0001d1e1c0 - 0001d2a1c0] BOOTMEM
[ 0.000000] #19 [0001d2b000 - 0001d2c000] BOOTMEM
[ 0.000000] #20 [0001d17440 - 0001d17481] BOOTMEM
[ 0.000000] #21 [0001d174c0 - 0001d17503] BOOTMEM
[ 0.000000] #22 [0001d17540 - 0001d178c0] BOOTMEM
[ 0.000000] #23 [0001d178c0 - 0001d17928] BOOTMEM
[ 0.000000] #24 [0001d17940 - 0001d179a8] BOOTMEM
[ 0.000000] #25 [0001d179c0 - 0001d17a28] BOOTMEM
[ 0.000000] #26 [0001d17a40 - 0001d17aa8] BOOTMEM
[ 0.000000] #27 [0001d17ac0 - 0001d17b28] BOOTMEM
[ 0.000000] #28 [0001d17b40 - 0001d17ba8] BOOTMEM
[ 0.000000] #29 [0001d17bc0 - 0001d17c28] BOOTMEM
[ 0.000000] #30 [0001d17c40 - 0001d17ca8] BOOTMEM
[ 0.000000] #31 [0001d17cc0 - 0001d17d28] BOOTMEM
[ 0.000000] #32 [0001d17d40 - 0001d17da8] BOOTMEM
[ 0.000000] #33 [0001d17dc0 - 0001d17e28] BOOTMEM
[ 0.000000] #34 [0001d17e40 - 0001d17ea8] BOOTMEM
[ 0.000000] #35 [0001d17ec0 - 0001d17f28] BOOTMEM
[ 0.000000] #36 [0001d17f40 - 0001d17fa8] BOOTMEM
[ 0.000000] #37 [0001d2a1c0 - 0001d2a228] BOOTMEM
[ 0.000000] #38 [0001d17fc0 - 0001d17fe0] BOOTMEM
[ 0.000000] #39 [0001d2a240 - 0001d2a260] BOOTMEM
[ 0.000000] #40 [0001d2a280 - 0001d2a2a0] BOOTMEM
[ 0.000000] #41 [0001d2a2c0 - 0001d2a2e0] BOOTMEM
[ 0.000000] #42 [0001d2a300 - 0001d2a320] BOOTMEM
[ 0.000000] #43 [0001d2a340 - 0001d2a3aa] BOOTMEM
[ 0.000000] #44 [0001d2a3c0 - 0001d2a42a] BOOTMEM
[ 0.000000] #45 [0001e00000 - 0001e1e000] BOOTMEM
[ 0.000000] #46 [0001e80000 - 0001e9e000] BOOTMEM
[ 0.000000] #47 [0001f00000 - 0001f1e000] BOOTMEM
[ 0.000000] #48 [0001f80000 - 0001f9e000] BOOTMEM
[ 0.000000] #49 [0001d2a440 - 0001d2a448] BOOTMEM
[ 0.000000] #50 [0001d2a480 - 0001d2a488] BOOTMEM
[ 0.000000] #51 [0001d2a4c0 - 0001d2a4d0] BOOTMEM
[ 0.000000] #52 [0001d2a500 - 0001d2a520] BOOTMEM
[ 0.000000] #53 [0001d2a540 - 0001d2a670] BOOTMEM
[ 0.000000] #54 [0001d2a680 - 0001d2a6d0] BOOTMEM
[ 0.000000] #55 [0001d2a700 - 0001d2a750] BOOTMEM
[ 0.000000] #56 [0001d2c000 - 0001d34000] BOOTMEM
[ 0.000000] Memory: 2026172k/2080768k available (5708k kernel code, 1148k absent, 53448k reserved, 5382k data, 908k init)
[ 0.000000] SLUB: Genslabs=14, HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] RCU-based detection of stalled CPUs is disabled.
[ 0.000000] Verbose stalled-CPUs detection is disabled.
[ 0.000000] NR_IRQS:4352 nr_irqs:712
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] allocated 20971520 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1666.674 MHz processor.
[ 0.010018] Calibrating delay loop (skipped), value calculated using timer frequency.. 3333.34 BogoMIPS (lpj=16666740)
[ 0.010030] pid_max: default: 32768 minimum: 301
[ 0.010092] Security Framework initialized
[ 0.010138] AppArmor: AppArmor initialized
[ 0.010143] Yama: becoming mindful.
[ 0.010766] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.012686] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.013535] Mount-cache hash table entries: 256
[ 0.013870] Initializing cgroup subsys ns
[ 0.013883] Initializing cgroup subsys cpuacct
[ 0.013895] Initializing cgroup subsys memory
[ 0.013915] Initializing cgroup subsys devices
[ 0.013921] Initializing cgroup subsys freezer
[ 0.013927] Initializing cgroup subsys net_cls
[ 0.013988] CPU: Physical Processor ID: 0
[ 0.013995] CPU: Processor Core ID: 0
[ 0.014000] mce: CPU supports 5 MCE banks
[ 0.014015] CPU0: Thermal monitoring enabled (TM1)
[ 0.014026] using mwait in idle threads.
[ 0.014031] Performance Events: PEBS fmt0+, Atom events, Intel PMU driver.
[ 0.014049] ... version: 3
[ 0.014054] ... bit width: 40
redcar9
Post by redcar9 »
[ 0.748088] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
cctv@cctv-desktop:~$ sudo aptitude install gspca-source -y
[sudo] password for cctv:
sudo: aptitude: command not found
redcar9
Post by redcar9 »
cctv@cctv-desktop:~$ ^C
cctv@cctv-desktop:~$ 0.014054] ... bit width: 40
g
0.014054]: command not found
cctv@cctv-desktop:~$ [ 0.014059] ... generic registers: 2
bash: [: missing `]'
cctv@cctv-desktop:~$ [ 0.014064] ... value mask: 000000ffffffffff
cctv@cctv-desktop:~$ [ 0.014069] ... max period: 000000007fffffff
cctv@cctv-desktop:~$ [ 0.014074] ... fixed-purpose events: 3
cctv@cctv-desktop:~$ [ 0.014079] ... event mask: 0000000700000003
cctv@cctv-desktop:~$ [ 0.021623] ACPI: Core revision 20100428
cctv@cctv-desktop:~$ [ 0.048078] ftrace: converting mcount calls to 0f 1f 44 00 00
cctv@cctv-desktop:~$ [ 0.048090] ftrace: allocating 22680 entries in 89 pages
cctv@cctv-desktop:~$ [ 0.050129] Setting APIC routing to flat
cctv@cctv-desktop:~$ [ 0.050549] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
cctv@cctv-desktop:~$ [ 0.160731] CPU0: Intel(R) Atom(TM) CPU D510 @ 1.66GHz stepping 0a
bash: syntax error near unexpected token `('
cctv@cctv-desktop:~$ [ 0.170000] Booting Node 0, Processors #1 #2 #3 Ok.
cctv@cctv-desktop:~$ [ 0.670021] Brought up 4 CPUs
cctv@cctv-desktop:~$ [ 0.670030] Total of 4 processors activated (13333.55 BogoMIPS).
cctv@cctv-desktop:~$ [ 0.671650] devtmpfs: initialized
cctv@cctv-desktop:~$ [ 0.671851] regulator: core version 0.5
cctv@cctv-desktop:~$ [ 0.671898] Time: 23:56:21 Date: 04/14/11
cctv@cctv-desktop:~$ [ 0.671995] NET: Registered protocol family 16
cctv@cctv-desktop:~$ [ 0.672024] Trying to unpack rootfs image as initramfs...
cctv@cctv-desktop:~$ [ 0.672327] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
a
