first of all, sry for my bad english, im danish but im sure you will understand..
since my raid5 crashed some nights ago, my zoneminder server was lost, so im creating a new one since i like zoneminder so much
i set up an ubuntu 10.10 server edition, with zoneminder v 1.24.2, with a axis webcam.. wich is working great !...... but
i cant export to zip or tar, i just says "export filed", and nothing else happens, is this a known issue?
then i tried to go to the "Video" tab on an event, to generate an avi file of the event, but as soon a i click the "Video" link i get an error saying:
An error has occurred and this operation cannot continue.
For full details check your web logs for the code '<random number/letter combination >'
[Sun Apr 17 20:48:23 2011] [error] [client <ip of computer accessing the webinterface of zoneminder>] SQL-ERROR(AD06A8): Unknown column 'undefined' in 'where clause', referer: hxxp://<ip of server>/index.php?view=event&eid=1&filter[terms][0][attr]=MonitorId&filter[terms][0][op]=%3D&filter[terms][0][val]=1&sort_field=StartTime&sort_asc=1&page=1
From what i can see, its seaching the sql database for "undefined" which does not exists, and therefore the error..
But my question here is then, where the hell does it get the "Undefined" from? clearly someone something is not defined???, but what is not defined?? anyone here who knows? any help would help a LOT!
(i will not be around to answer the rest of the day today, but i will check back as the first thing tomorrow!)
-Steffan
