Page 1 of 1
"Add new monitor" button disabled
Posted: Sat Apr 23, 2011 4:53 pm
by vader88
I went through a step by step tutorial to get zoneminder running on Ubuntu Server. After getting it running I added an dlink ip camera. I have been using zoneminder for a few days with that camera with no problem. I have fiddled with settings in zoneminder as well.
Now I have got a new camera that I want to add but the "Add new monitor" button is disabled on the interface. So is the checkbox for my current monitor. Why might this be?
Re: "Add new monitor" button disabled
Posted: Sat Apr 23, 2011 10:36 pm
by vader88
I have found that disabling OPT_USE_AUTH enabled the add new monitor button. I then added the new camera and it was working fine then i tried re-enabling authentication and my new monitor disappeared and the button is disabled again. It was using hashed and switching to plain has not fixed the problem.
Posted: Sun Apr 24, 2011 5:23 am
by mastertheknife
Have you modified the admin account?
Also, de-select any selected monitors in the admin's account settings.
mastertheknife.
Posted: Sun Apr 24, 2011 2:13 pm
by vader88
Thanks for the info. The first camera I had got was selected in the restricted monitors section. Unfortunately de-selecting it has not fixed the problem even after rebooting. The admin user appears to have all permissions at the fullest as well.
Posted: Sun Apr 24, 2011 5:24 pm
by vader88
Well, I just tried it again and it decided to work this time. I don't know what I did to fix it. I don't know enough about linux and have been barely getting by with this whole setup. I have been trying to get emailing from zoneminder working by installing certain perl modules.
