No image in TP Link TLSC-3000 and TLSC-3130G
jsilva
Post by jsilva »
I have v1.23.3 of zoneminder and i trying to configure these IP cameras TP Link.
The cameras are working properly and transmit images directly from your IP.
In web page of zoneminder, I can't see any image.
For the TLSC-3000, i followed directions from zoneminder oficial page and configured this settings:
Remote Protocol - RTSP
Remote Method - RTSP
Remote Host Path / live/mpeg4
Remote Image Colours - 24 bit color
Capture Width (pixels) - 640
Capture Height (pixels) - 480
When i trying access the zone of the camera, image not load and get a blank image.
For TLSC-3130G is the same problem.
Has anyone resolved a similar situation? What i need to configure in zoneminder?
Can someone help?
Regards
bb99
Re: No image in TP Link TLSC-3000 and TLSC-3130G
Post by bb99 »
First thing to check based on your posted settings is the "shared memory" settings. The "134217728" shmmax value is too low for 640*480. My suggestion is to double it.
http://www.zoneminder.com/wiki/index.ph ... esolutions
jsilva
Post by jsilva »
bb99 wrote:First thing to check based on your posted settings is the "shared memory" settings. The "134217728" shmmax value is too low for 640*480. My suggestion is to double it.
Thanks for answer bb99,
I changed memory settings to double or higher but without success.​​ After restart the zoneminder, still not sending image.
Any suggestions?
bb99
Post by bb99 »
Should have caught this right off, sorry, but check to make sure that rtp/rstp isn't an option for "remote method". If it isn't then these settings are for 1.24.x. If I remember correctly rstp was fledgling in 1.23.3 (1.23.x) and there were issues.
