I have one cam for user.
I wonder if there is a possibility of emailing a specific user.
That is, each user would have an email and when an event was created only the particular user will receive the mail.
Send MultiMail to Multiusers
Re: Send MultiMail to Multiusers
I believe you could send the mail to multiple users if you edit your /usr/bin/zmfilter.pl and add a line for each user email:
Look for the line containing MIME::Lite->send , and change it to be something like:
MIME::Lite->send( "smtp", ZM_EMAIL_HOST, Timeout=>60, AuthUser=>'your@email.com', AuthPass=>'yourpass' );
For each email account, the only thing is that you may need the password of each account, try it without the pwd just in case.
Hope it helps,
PacoLM
Hope it helps,
PacoLM
