I have Zoneminder 1.24.2 running on Ubuntu and all is working well. I would like to use IP camera viewer that is available for the android.
http://hit-mob.com/ip-cam-viewer-android/
When setting up the application, it has
make: zoneminder
model: zoneminder Camera Server
host ip: dyndns.mydomain.com
http port: 80 ---> I have my firewall forwarding port 80 to the zoneminder box which is listening on port TCP 80
port: 80
channel: 1
username: admin account on zoneminder
password: password for admin account on zoneminder
and it doesnt connect. How would I setup zoneminder to these specs so that I can connect from my android to the zoneminder system?
Zoneminder 1.24.2 remotely using IP Camera Viewer Android
- punch-card
Re: Zoneminder 1.24.2 remotely using IP Camera Viewer Androi
Try Tiny Cam, its works very well and easy to setup.... The basic version free and will handle up to 4 cameras.
Also if you have a firewall, make sure port 80 is open.
http://www.zoneminder.com/forums/viewto ... =9&t=16688
http://tinycammonitor.com/
Best Regards
Mike
Mike
I second TinyCam, it is the best I have used. The only issue/annoyance I have ran in to with TinyCam is the amount of network power it uses. I have an Android Tablet that has tinycam installed and is run 24/7 with my 4 cameras displayed. When I run this in Mpeg mode on TinyCam, it cripples my bandwidth on my network. However, you can select it to do jpeg, it doesn't cause this problem but the fps on your device may be slower.
