I am running ZoneMinder 1.24.2 on CentOS5.5 (64 bit).
I finished installing Zoneminder with these instructions:
http://www.zoneminder.com/wiki/index.php/CentOS
And some other misc. stuff I found on the forums and online. Everything went off without a hitch up until:
cp: accessing '/var/www/html/zm/': Not a directory
chown: cannot access '/var/www/html/zm/cambozola.jar': Not a directory
The **s are ts because it would not let me post the correct way because I am a spam bot or something.You have chosen to open
zm
which is a: application.octet-stream
What should Firefox do with this file?
So it seems everything is installed except the cambozola web interface, but I can't get it to install correctly. Help?
