On 64-bit ubuntu I get the following issues:
a) Montage does not recognize selecting grids other than a width of one. (So for example you can't view 2 cameras across).
b) When creating/editting zones, the coor1dinates of the zone are not displayed. Hence, the +/- function that allows
one to make various shapes doesn't work. Also, probably related is that you can't click on a point and move it.
If this is an ubuntu problem are their work arounds?
Thx!
64-bit issues - Montage / Zones
Renamed Ubuntu 11.04 was Re:: 64-bit issues - Montage / Zone
It would appear to be an ubuntu 11.04 issue.
The behavior is the same on both 32 bit and 64 bit versions of the OS.
In both these, synaptic installs zoneminder 1.24.2.
Re: 64-bit issues - Montage / Zones
Where is the proper place to report this?
Does it go to ubuntu - who I would assume play a role in configuration of zoneminder - or is it a zoneminder issue.
I'll poke around the source and mysql databases to see if something is obvious.
I was thinking perhaps some run once script that sets up the mysql tables failed at installation time.
Turning zoneminder debug on does not flush out the problem.
Hi, first check this.
Just to confirm this fixed it 100% for meSVLaller wrote:Hi, first check this.
Don't forget to match the file names if you're using a new version of mootools (like i have).
