Elderly Parent Monitor
jeffs555
Post by jeffs555 »
There are commercial systems for monitoring elderly people living alone that track and memorize normal movement patterns around the house. They can issue alerts when abnormal movement patterns occur or when normal movements fail to occur. Sort of an "I've fallen and can't get up" system that can alert even if they can't press the panic button.
Does anyone know of any low cost or preferably open source programs to address similar concerns?
kingofkya
Re: Elderly Parent Monitor
Post by kingofkya »
I think the opencv project is what your looking for used to track diffrent movements like say falling down.
http://www.zoneminder.com/forums/viewto ... 1&start=15
Theres also the kinetic projects:
http://www.youtube.com/watch?v=rKhW-cvpkks
Ether way currently there is no ready made solution.
kenvinlee89
Post by kenvinlee89 »
Thanks you for the post.
Hi guys, Im a newbie. Nice to join this forum.
