Include username and password in HTML link to zoneminder
When I access ZM from my mobile phone it is a pain to enter my username and password. Is there a method to include username and password in the HTML link? For example some systems (lots of cams) allow http://username:password@domain/.... to bypass login prompts. an I do this for a link to enter ZM?
Running Ubuntu 11.04 64bit Zoneminder 1.24.3 from SVN, FFmpeg, libjpeg-turbo, Webmin, Cambozola
Re: Include username and password in HTML link to zoneminder
you want to put this link somewhere on other page ? right?
I use such solution .... copy part of login page , and make fields hidden ...
and I have "button" ...
check it , change your URL , user, pass
this will open main page of zone minder .... hope this helped
unfortunately I do not know (yet) how to make other page work , as example monitor ...
<form name="loginForm" id="loginForm" method="post" action="http://YOURIP.COM/zm/index.php" target="_blank">
<input name="action" value="login" type="hidden">
<input name="view" value="postlogin" type="hidden">
<table id="loginTable" class="minor" cellspacing="0">
<tbody>
<tr>
<td class="colRight"><input name="username" value="USERHERE" size="12" type="hidden"></td>
</tr>
<tr>
<td class="colRight"><input name="password" value="PASSHERE" size="12" type="hidden"></td>
</tr>
</tbody>
</table>
<input value="ENTER" type="submit" >
</form>
- zoneminder
- Site Admin
- Contact:
If you change the ZM authentication method to remote you can then set up a htaccess file to manage authentication for your system. You can then use the user:pass@ format for logging in but it will be global.
Phil
