I installed zm on kubuntu 11.04 via sudo apt-get and proceeded to get apache2 up and running. I now run
sudo etc/init.d/apache2 start
sudo etc/init.d/zoneminder start
On my localhost I try to add a new monitor. I have three webcams I am trying, my laptop integrated webcam, an AVEO webcam(?) and a sonix-technology webcam. I fill in the add-new monitor in accordance with the wiki, and put either /dev/video0 or 1 or 2 respectively. However, I have never had anything but a broken link on firefox 4.0.1 or a black square, no timestamp on reconq 0.7.0.
xawtv works for all, and I am able to take pictures.
looking at just video1 for now, so not my laptop integrated webcam:
running xawtv gives the following:
xawtv -c /dev/video1
This is xawtv-3.95.dfsg.1, running on Linux/x86_64 (2.6.38-8-generic)
xinerama 0: 1280x800+0+0
/dev/video1 [v4l2]: no overlay support
v4l-conf had some trouble, trying to continue anyway
Warning: Cannot convert string "-*-ledfixed-medium-r-*--39-*-*-*-c-*-*-*" to type FontStruct
ioctl: VIDIOC_G_STD(std=0x1b3a110 [PAL_I,PAL_M,NTSC_M_JP,?,SECAM_B,SECAM_D,SECAM_K,SECAM_K1,?ATSC_8_VSB,ATSC_16_VSB]): Invalid argument
ioctl: VIDIOC_S_STD(std=0x0 []): Invalid argument
zmu -d /dev/video1 -q -v
Video Device: /dev/video1
General Capabilities
Driver: uvcvideo
Card: USB2.0 Camera
Bus: usb-0000:00:1d.0-1.1
Version: 1.0.0
Type: 0x4000001
Supports video capture (X)
Does not support video output
Does not support frame buffer overlay
Does not support VBI capture
Does not support VBI output
Does not have tuner
Does not have radio
Does not support read/write i/o (X)
Does not support async i/o
Supports streaming i/o (X)
Standards:
Formats:
YUV 4:2:2 (YUYV) (YUYV)
Crop Capabilities
Bounds: 320 x 240
Default: 320 x 240
Current: Cropping is not supported
Inputs: 1
Input 0
Type: Camera
Audioset: 00000000
Standards: 0x0
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
xawtv -hwscan
looking for available devices
port 77-92
type : Xvideo, image scaler
name : Intel(R) Textured Video
/dev/video0: OK [ -device /dev/video0 ]
type : v4l2
flags: capture
/dev/video1: OK [ -device /dev/video1 ]
type : v4l2
flags: capture
/dev/video2: OK [ -device /dev/video2 ]
type : v4l2
name : USB 2.0 Camera
flags: capture
I am just testing zoneminder at the moment and intend to run a dedicated machine that will also control other aspects of my house like heating and lighting, so the distro I use in the end can be different. Is there a distro more suited or with incredibly easy steps? I am also going to buy proper analog CCTV cameras that zoneminder will be able to use at that time.
Thank you
