ZM 1.24.3 armv5tel porting
PacoLM
Post by PacoLM »
I would like to test this new version in my ARM based plug computer. Do I need to recompile it or should be available from a repository to install it using the apt-get?.
Thanks in advance,
PacoLM
zoneminder
Site Admin
Re: ZM 1.24.3 armv5tel porting
Post by zoneminder »
Almost certainly recompile I would expect if you want the latest version. There may be a version 1.24.2 available from a repository depending on what your distro is.
Phil
PacoLM
Post by PacoLM »
I have installed & running the version 1.24.2 long time ago. It works perfectly after fine tune all the settings in the guruplug running debian. I have donated!, It's a fantastic application. What I wanted is to know if the new version will be available in the repositories soon (no hurries), or if I should download the new version and try to recompile it in my system.
Thanks for the quick response and the wonderful application!
PacoLM
