Problem is the sources are staying red and i can't get any video. I however can see the picture in xawtv.
UPDATE FOUND THIS IN THE VAR LOGS
May 20 18:11:58 tempe-Dimension-4700 zmc_dvideo0[2728]: FAT [Failed to open video devic e /dev/video0: Permission denied]
Permissions issue i am thinking, just no sure how to fix it...
Here's the output of the following command while i have 2 cameras connected. Any ideas on how to get this to work?
zmu -d /dev/video0 -q -v
tempe@tempe-Dimension-4700:~$ zmu -d /dev/video0 -q -v
Video Device: /dev/video0
General Capabilities
Driver: bttv
Card: BT878 video (GrandTec Multi Cap
Bus: PCI:0000:03:00.0
Version: 0.9.18
Type: 0x5000015
Supports video capture (X)
Does not support video output
Supports frame buffer overlay
Supports VBI capture
Does not support VBI output
Does not have tuner
Does not have radio
Supports read/write i/o (X)
Does not support async i/o
Supports streaming i/o (X)
Standards:
NTSC
NTSC-M
NTSC-M-JP
NTSC-M-KR
PAL
PAL-BG
PAL-H
PAL-I
PAL-DK
PAL-M
PAL-N
PAL-Nc
PAL-60
SECAM
SECAM-B
SECAM-G
SECAM-H
SECAM-DK
SECAM-L
SECAM-Lc
Formats:
8 bpp, gray (GREY)
8 bpp, dithered color (HI24)
15 bpp RGB, le (RGBO)
15 bpp RGB, be (RGBQ)
16 bpp RGB, le (RGBP)
16 bpp RGB, be (RGBR)
24 bpp RGB, le (BGR3)
32 bpp RGB, le (BGR4)
32 bpp RGB, be (RGB4)
4:2:2, packed, YUYV (YUYV)
4:2:2, packed, UYVY (UYVY)
4:2:2, planar, Y-Cb-Cr (422P)
4:2:0, planar, Y-Cb-Cr (YU12)
4:2:0, planar, Y-Cr-Cb (YV12)
4:1:1, planar, Y-Cb-Cr (411P)
4:1:0, planar, Y-Cb-Cr (YUV9)
4:1:0, planar, Y-Cr-Cb (YVU9)
Crop Capabilities
Bounds: 1063 x 608
Default: 924 x 576
Current: 924 x 576
Inputs: 4
Input 0
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
Input 1
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 2
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 3
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
dmesg | grep bttv
tempe@tempe-Dimension-4700:/usr/bin$ dmesg | grep bttv
[ 20.087967] bttv: driver version 0.9.18 loaded
[ 20.087974] bttv: using 8 buffers with 2080k (520 pages) each for capture
[ 20.088147] bttv: Bt8xx card found (0).
[ 20.088173] bttv 0000:03:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 20.088191] bttv0: Bt878 (rev 17) at 0000:03:00.0, irq: 16, latency: 64, mmio: 0xd0101000
[ 20.088444] bttv0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
[ 20.088503] bttv0: gpio: en=00000000, out=00000000 in=00f36fff [init]
[ 20.088618] bttv0: tuner absent
[ 20.088622] bttv0: the autoload option is obsolete.
[ 20.088625] bttv0: use option msp3400, tda7432 or tvaudio to
[ 20.088629] bttv0: override which audio module should be used.
[ 20.088768] bttv0: registered device video0
[ 20.088853] bttv0: registered device vbi0
[ 20.088876] bttv0: PLL: 28636363 => 35468950 .
tempe@tempe-Dimension-4700:/var/log/zm$ lspci
00:00.0 Host bridge: Intel Corporation 82915G/P/GV/GL/PL/910GL Memory Controller Hub (rev 04)
00:01.0 PCI bridge: Intel Corporation 82915G/P/GV/GL/PL/910GL PCI Express Root Port (rev 04)
00:02.0 VGA compatible controller: Intel Corporation 82915G/GV/910GL Integrated Graphics Controller (rev 04)
00:02.1 Display controller: Intel Corporation 82915G Integrated Graphics Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) PCI Express Port 1 (rev 03)
00:1d.0 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #1 (rev 03)
00:1d.1 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #2 (rev 03)
00:1d.2 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #3 (rev 03)
00:1d.3 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #4 (rev 03)
00:1d.7 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB2 EHCI Controller (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev d3)
00:1e.2 Multimedia audio controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) AC'97 Audio Controller (rev 03)
00:1f.0 ISA bridge: Intel Corporation 82801FB/FR (ICH6/ICH6R) LPC Interface Bridge (rev 03)
00:1f.1 IDE interface: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) IDE Controller (rev 03)
00:1f.2 IDE interface: Intel Corporation 82801FB/FW (ICH6/ICH6W) SATA Controller (rev 03)
00:1f.3 SMBus: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) SMBus Controller (rev 03)
02:00.0 Network controller: Broadcom Corporation BCM4321 802.11a/b/g/n (rev 03)
03:00.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
03:00.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
03:08.0 Ethernet controller: Intel Corporation 82562ET/EZ/GT/GZ - PRO/100 VE (LOM) Ethernet Controller (rev 03)
