I had all the events stored in the disk but I lost all the data of Frames and Events tables in database, It's posible to rebuild the Frames and Events tables?.
thanks
Urgent !!!
Re: Urgent !!!
You cannot recover all the meta data obviously if you lost the entire database but if you are decent at coding in any language you should be able to insert enough entries and fake data to be able to view events and using file timestamps to have them properly dated.
