I am trying to stream video from a webcam attached to my Fon 2.0n router using the latest Fonera firmware. As some may know that this excellent piece of hardware has a USB port and software (cambozola) to utilize the USB port for streaming. I have retrieved the path the stream uses however, it changes every time I log in and out of the router. Is there a work around to get ZM to see this path change? The path is:
<IP of Cam>/luci/;stok=XXXXXXXXXXXXXXXXXX/fon_devices/fon_webcam
The stok=XXXXXXXXXXXXXXXXXX is the only part of the path that changes, the rest is static. I have tried to put username:password@host_ip (with my specific parameters) in the host path of a remote cam inside of ZM but that does not help. Any advice? Is this a restriction within the stock Fon firmware? Would installing different firmware on the router solve this issue?
Thanks in advance.
Trouble Streaming Fonera 2.0n webcam to ZM
Re: Trouble Streaming Fonera 2.0n webcam to ZM
I am running ZM version 1.24.2 on an Ubuntu 10.04 virtual machine. The virtual machine software is in Xen 4.1 in case any of this may matter.
Thanks.
Thanks.
I'd ask fonera if there is another path you can use that redirects to the correct path.
I did that and waiting for a response. I will post the thread from Fon for the community if it gets resolved. Thanks.
